Question about Kawasaki low seat
This is a discussion on Question about Kawasaki low seat within the General Ninja 650R forums, part of the Kawasaki Ninja 650R category; Is the seat built on a lower seat pan or is it just padded differently? My wife is vertically challenged and I need to drop ...
Results 1 to 11 of 11
    Newbie ScottJA's Avatar
    Apr 2011
    5
    My wife is vertically challenged and I need to drop some height off the seat as well as the suspension on her bike. I've got Soupy's link on the way to handle the suspension but I need to figure out the best way to shed as many inches off the bike as is safe.
    Ayu
    Ayu is offline
    Site Elder Ayu's Avatar
    Jun 2010
    Milwaukee, WI
    41
    516
    41 times
    I have the lowered seat and it helped a lot for me. The new lowered seat is 1 inch lower and almost an inch thinner in the inseam area. The combination of being 1 inch lower with thinner sides allowed me to flat foor the bike at 5 feet 5 inches with a 28 inch inseam. You may also want to look into the LadyStar boot but the boots are expensive.
    Zero Gravity Double Bubble (dark smoke), Soupy's Performance lowering link (09 Prototype - REMOVED), Soupy's Performance Adjustable Kickstand, RAM GPS Handlebar Mount w/IPAD mini, GOLD No Cut Frame Slider, Motowerk Footpeg Lowering block, Penske 8983 rear shock, RaceTech Gold Valve Emulator fronts, Power Commander V with AutoTune, and BMC Performance Air Filter.
    Ninja 650R '09 - Black
    Ninja ZX10R - SOLD
    Ninja 250R - SOLD
    Suzuki M50 Special - SOLD
    Honda SilverWing - SOLD
    Apr 2011
    5
    Quote Originally Posted by Ayu View Post
    Thanks. The wife stands a mighty 5'2" and I think has a 27 or 28" inseam. Her previous bike (SV650s) had a factory low seat and the seat pan itself was an inch lower. I took that to an upholsterer and got it another 1" lower and with better foam. Combined with 2" lowering links, I got it down 4" below stock to the top of the seat. If you say it is narrower, that implies it is likely a different seat pan. I may just have to drop the $300+ and get it and then have some upholstery magic done to bring it down another 1".
    Site Elder Glocken's Avatar
    Mar 2010
    Brooklyn, NY
    747
    Quote Originally Posted by ScottJA View Post
    wow, that's A LOT of lowering haha. Shouldn't your wife be able to flatfoot with just 2 inchs lowered? since you said she has around 27/28" inseam? I too have 28" inseam, I'm unable to flatfoot but I've learned to live with it.
    '06 650R RIP
    '05 Sv650s
    Ayu
    Ayu is offline
    Jun 2010
    Milwaukee, WI
    41
    516
    41 times
    The lowered seat has better foam but I don't know if you can take away from it anymore without compromising comfort. I think your wife may be okay with just the new lowered seat and dropping the bike an inch with Soupys Peformance lowering bracket. Stock bike seat is 31.1 inches high. The lowering link will take it down to 30.1 inches, the seat should drop it down to 29.1, the thinner sides should also drop it another half inch. So you're now at 28.6 inches, added a decent pair of riding boot with thicker heel and you should be right around 27-28 inches. Keep in mind that if you keep the stock bars, you'll need to lower the front by about 20-22mm to keep the bike geometry. I have mine lowered 22mm and I have about 2-3mm clearance from the top of the forks...just something to think about.
    Ninja ZX10R - SOLD
    Ninja 250R - SOLD
    Up-And Comer abyssdncr's Avatar
    Mar 2011
    Wichita, KS
    58
    We've got the low seat, lowering link, and 2.5" heels put together to get my wife to where she can flatfoot. Link made her competent, seat made her confident, and boots were the icing on the cake to flatfoot. She's 5'2" with about a 27" inseam, maybe 27.5"...
    It's the exact same pan, just the foam is different. As stated before, there's not much left to take out of the "low" seat, so don't bank on that plan.
    2009 650R, Dark Arrow Exhaust, Ninja650Shop sliders, OEM low seat, Moto Werk lowering link, front end slipped 1", OEM 2010 grab handles, Vista Cruise throttle lock, on-board garage door opener, Sylvania Silverstar high beam, Autocom equipped, tank pad, grip puppies, SW Motech rear rack, & Givi E370NT...
    Apr 2011
    5
    I can't really do much for the boots. My wife and I are both active duty Army so it's combat boots Monday through Friday. I installed the Soupy's link this afternoon and she notices the difference. She can now get the balls of her feet firmly on the ground. a note on the soupy's link: one of the coils on the shock is now touching a part of the sub-frame when the shock is under momentary load e.g. speed bumps and pot holes. It will eventually wear less than 1mm off of it, mostly the finish. I don't consider it a deal breaker, but it does make a noticeable noise at low speed until it wears the spot down. It did fine on the test ride though!
    If the factory low seat is built on the same seat pan, I have an upholsterer locally who can swap out and redo the foam to achieve the same result and it will cost us less than $100. That should set her up perfectly. He can make it lower and put better quality foam in at the same time.
    I appreciate the help and suggestions. I used to post to this forum in the early 2000's when I had a ZR7s. I actually bought my Z from a guy on this forum. The Army has decided I will be spending the next few months in the sandbox so I think I will be reading up on the 650R in my spare time and getting re-aquianted with riderforums.
    After putting about 75 miles on the wife's bike I believe this will be my next motorcycle. It reminds me of my ZR7 and strikes me as what I always wanted from my ZR7...namely modern upgrades like fuel injection and better brakes.
    Newbie Bounty Hunter's Avatar
    May 2011
    Omaha, NE
    I've considered the low seat. I can touch on my forefoot, but I could probably flat foot if I went with it. One thing I've wondered is if it changes the rider position to make it uncomfortable or do you guys adjust the position of your pegs as well?
    Site Elder tp555's Avatar
    Oct 2008
    SC
    517
    18 times
    I got one FS.Posted here a while ago.That is the kawa lowered seat. I got my stock seat done by Spencer and its a bit higher but good enough.
    Site Elder Zandit's Avatar
    Mar 2010
    Tasmania, Australia
    699
    90 times
    Scott, alot of people have mentioned the spring touching on the subframe, have you tried rotating the spring(It moves easily...well it should at least!) that should take the rubbing out of the equation!
    2010 Kawasaki Ninja 650R ABS Island Metallic Blue.
    PC5, Yoshi Exhaust, Sport Bars 3.0, Progrip 717 Grips,Pirelli Angel Tyres, CF Rimtape, Bar ends & Spools, Givi Luggage, New Ninja Decals, Double Adjustable Levers, TonyBKK's Frame Sliders, Zero Gravity DB Windscreen in Dark Smoke, Narva +120% Headlights and Blue LED Marker lights, and one Awesome Wing Nut between the seat and Handle bars!!!!
    Apr 2011
    5
    I haven't tried to rotate the spring. It didn't even occur to me. Thanks for pointing that out to me. I'll give it a shot tomorrow. It will also give me an excuse to test ride the "repair" to the wife's bike. I really like this bike.
can you lower a seat on a kawasaki ninja
kawasaki low seat
kawasaki lowered seat
lower seat for ninja 650
lower seats for ninja 650
ninja 650r low seat
ninja 650r lower seat
ninja 650r lowering seat
ninja 650r seat lower
seat lowering for kawasaki ninja 650 abs
