Questions
This is a discussion on Questions within the General Ninja 650R forums, part of the Kawasaki Ninja 650R category; When you are riding and you bend down behind the windscreen will this affect your control of the bike? In MSF they tell you to ...
Results 1 to 15 of 24
Thread: Questions
    Up-And Comer newbieJan07's Avatar
    May 2010
    Killeen, TX
    76
    Questions
    In MSF they tell you to sit up right while riding so I just wanted to know if it will affect how you control the bike.
    Also if you ride with no helment how do you keep the bugs from going splat on your face? (This is a real question I really want to know)
    Thank in advance
    Up-And Comer dudeonguitar's Avatar
    Apr 2010
    Bay Area, CA
    109
    Quote Originally Posted by newbieJan07 View Post
    Thank in advance
    What they teach you in MSF is for riding on the street at relatively low speeds. Counter-steering won't really work at high speed canyon carving for instance. It's perfectly ok to hug the gas tank if that's as low as you want...reduces the wind buffeting and keeps you in attack mode while cornering.
    As to riding without a helmet, be ready to be
    Earth bound, Misfit I
    May 2010
    Killeen, TX
    76
    Quote Originally Posted by dudeonguitar View Post
    Okay that make sense....
    I don't plan on ever riding with out a helmet... In TX you don't have to and I see so many with out it I was just thing how do they keep the bugs off
    Supreme Being Azweepay's Avatar
    Feb 2008
    Panama City, FL
    1,085
    Off topic, but I'm curious. Did they make you drain the tank for your move?
    Rising Star donovan's Avatar
    Mar 2010
    NH, USA
    171
    That sounds like misinformation. Doesn't the bike countersteer at any speed above parking lot speeds? If not, how else is it steering?
    El Cajon, Ca.
    12,773
    12 times
    Not necessarily. Riding on the range is at relatively low speed or they couldn't find big enough places to put the ranges.
    El Cajon, Ca.
    12,773
    12 times
    Yes, it is.
    Site Elder Nicklovin's Avatar
    Mar 2010
    Westchester, NY
    23
    679
    Thank in advance
    If anything I would have to say it increases your control. The reason you lean down in the first place is to increase aerodynamics and because at higher speeds it is easier to control the bike when the wind is working for you instead of against you (literally).
    As far as bugs go, I just spray my face with bug spray; the bugs avoid me all together. Make sure you keep you eyes and mouth open though for that extra protection.
    Oh and @dudeonaguitar on the "counter-steering doesn't really work at highspeeds" comment...
    There are only two ways to steer a motorcycle. Turning the handle bars and counter steering. Whether your realize your doing it or not, even if you are leaning completely off the bike in every turn and keeping it upright, at some point you will need to exercise some degree of counter steering. That being said, if counter steering does not work at high speeds...your only other option is to turn your handle bars (assuming your not on a perfectly straight road, and not changing lanes). Let me know how that goes for you.
    May 2010
    Killeen, TX
    76
    Quote Originally Posted by Azweepay View Post
    Yup they sure did.. it wasn't too bad it was much easier then I thought it was going to be...
    Supreme Being steveinsandiego's Avatar
    north san diego county
    2,005
    32 times
    Quote Originally Posted by Nicklovin View Post
    a disastrous wreck, i'm sure. to resist countersteering can only cause trouble as far as i know.
    May 2010
    Killeen, TX
    76
    [QUOTE=Nicklovin;621564]If anything I would have to say it increases your control. The reason you lean down in the first place is to increase aerodynamics and because at higher speeds it is easier to control the bike when the wind is working for you instead of against you (literally).
    Okay I was worried if I did it I would be able to see or control the bike correctly... But what you said make sense to me... I don't go over 70 cause Im not use to all the wind...
    Kool.. When I was seeing people with no helmet I was thinking of the big bug on my helmet on ther faces or a rock hitting them in the face...
    Mar 2010
    Westchester, NY
    23
    679
    Part 1 of my response was good info. The only issue you'll experience with hugging the tank is the 650R is caught between two styles of bike, Super Sport and Touring. Hence its official name "Sport Touring". That being said, because of the way the stock handle bars are designed, you may experience issues reaching your clutch/front brake levers unless you rotate them upwards. Also, because the stock handle bars come up the way they do, your arms will be on odd position with your forearm and bicept creating more of an 45 degree angle instead of a 90 degree angle like it should be.
    Part 2 of my response was me having a little fun. Those guys who ride sport bikes w/o a cruiser/touring style windshield and anything short of a full face helmet are taking bugs to the face. There is no way around that. I myself ride with my visor up a decent amount of the time, and every now and then I kick myself when I catch a large bug in the cheek, or a small annoying one in my eye...or one time a bee stuck in the ear slot, inside my helmet.
    Site Elder Lumberjack's Avatar
    Feb 2010
    703
    You can also steer the bike with your knees/hips - I've been playing with this a bit, slaloming back and forth in my lane using only inputs from the knees and hips - you have to sort of twist/torque your hips and push into the bike with your knees as you do so, with a bit of "english" on it - the bike will steer this way, and can make quick direction changes - I read somewhere they said that you can't make the bike turn at speed without handlebar input but this is not true..
    May 2010
    Killeen, TX
    76
    or one time a bee stuck in the ear slot, inside my helmet.[/QUOTE]
    I would have freaked out... I blink like crazy when a bug hits my helmet so a bee would make me pull over and do a crazy dance on the side of the road people will think I am crazy... lol...
    May 2010
    Killeen, TX
    76
    You can also steer the bike with your knees/hips - I've been playing with this a bit, slaloming back and forth in my lane using only inputs from the knees and hips - you have to sort of twist/torque your hips and push into the bike with your knees as you do so, with a bit of "english" on it - the bike will steer this way, and can make quick direction changes - I read somewhere they said that you can't make the bike turn at speed without handlebar input but this is not true..[/QUOTE]
