Removing the seat without the key?
This is a discussion on Removing the seat without the key? within the General Ninja 650R forums, part of the Kawasaki Ninja 650R category; I have an 07 650r and am in a bit of a situation
Is it possible to remove the seat from the bike without the ...
Newbie
Is it possible to remove the seat from the bike without the key?
I changed the oil for the first time on the bike last weekend without breaking anything or spilling oil everywhere in my garage. Unfortunately I noticed the next day.. that my key was nowhere to be found. Of course I was stupid enough to not make a spare, and as it was purchased used from a dealer, have no keycode. I cannot see how to remove the ignition without drilling it out (i've heard the keycode can be found on it), and I am about to have a locksmith come out and rekey it for ~$130.
I thought about it today and think there is a 1% chance the key may have ended up in the tool bag before i put it back under the seat and closed it up. Unfortunately i do not know how to get the seat off without a key. I can pry the seat up a decent ways and was thinking if there is a way to pop the seat lock without damaging it/the bike, it would be worth to see if the key is there. I'd hate to spend 130 and then find the key underneath.
Is this possible to do? I tried searching and didnt find an answer, but if my search skills are lacking i would certainly appreciate a link.
Thanks for any help you can provide and ride safe!
2007 Blue Ninja 650R
2008 Red Ninja 500R
05-21-10 04:04 PM
Im not sure that there is a way. Maybe take the side panel off of the bike and then try to access the cable that operates the locking mechanism at the rear of the bike.
Failing that my brother found a way of opening his.
Granted its a moped, but it made me think, hitting it on the lock in an upward motion. Pops right open
Though I wouldnt do that to our bikes, lol
Pull the left side tail-fairing off. Located the locking mech for the seat switch. Disconnect the cable from the lock cylinder and pull the cable. Seat should come loose.
2009 Ninja 650r - Black, the slow color.
Jardine GP-1 slip-on Exhaust | Vortex Racing clip-ons | Targa tail kit | Puig Dark smoke screen; custom cut for size (2 1/2 inches shorter than stock) |Front end lowered 1 1/4 inch | Gorilla Alarm | Ermax seat cowl, custom painted to match kawasaki passion red | SpeedyMoto swingarm sliders/spools. |Coolant temperature and Air/fuel mixture gauges, modded into front panel near cluster. | Airbox baffles removed, P.A.I.R valve plugged. | Vortex -1 front sprocket. | HealTech Speedohealer (-11.6% offset). | PowerCommander V. | R and G frame sliders. | Spiegler "3" steel line brake kit. | "Jeffo" Custom Map (
www.faic.cc) | Catalyst composites Race Tail | Pazzo Levers | Competition Werks Pegs
Major props to:
BRP; gary (
www.blueridgeperformance.net)
Ninja650shop; jen (
www.ninja650shop.com)
Newbie
I will try to get the fairing off tomorrow. I was messing with it the other day and it looked like a screw that was covered under the seat kept it in place, but i'll see what i can do
2008 Red Ninja 500R
Have the locksmith pick the lock for the seat first. Should take him 10 seconds if he is good. If the key isn't in there he can do the rekey.
twowheeladdict
I agree with twowheeladdict here. Problem with trying to remove the seat or fairing and messing with the lock mechanism yourself is your said only a 1% chance the key is there. If you damage any of these things for a 1% chance you will spend not only the $130 for the rekey but you will gave to replace anything else you damage in the chase for a possible key under the seat. 1% is a slim chance and a seat or fairing replacement can be costly.
Just my
Good Luck
08 Ninja 650
06 Ninja 650 Streetfighter (gone)
82 Yamaha XJ1100 (gone)
65 Stang
07 Stang GT
88 Porsche 944
Can the dealer get the key code from the VIN #?
Idk if they can use the VIN #, but when I bought my bike used, they gave me 2 keys and a little metal tag with a code on it. The tag is supposed to be used to order a new key from Kawasaki if I ever lose both of mine.
2007 Ninja 650R
2009 Pontiac G8 GT
Newbie
ok i will have the guy try to pick the seat first. good idea. I'm waiting until next week to get it done, but of course the weather is AMAZING this week -_-
Thanks for all the responses everyone!
2008 Red Ninja 500R
2007 kawasaki ninja 650r seat removal
2007 ninja 650r seat lock
650r ninja seat removal
how to open the seat on a kawasaki ninja
how to remove nibja 650r seat no key
how to remove ninja 250 seat without key
how to remove the seat on a ninja 650r
kawasaki 650r seat removal
key code on the key lock tail ninja
lock key cylinder on 2006 kawasaki ninja 650r
ninja 650r seat lock code not working in ignition cylinder
pop seat on a njnja
remove kawasaki ninja seat lock
