Spark Plug - REMOVAL
This is a discussion on Spark Plug - REMOVAL within the General Ninja 650R forums, part of the Kawasaki Ninja 650R category; How deep do you have to go to get to the spark-plugs ? I realize the seat, tank, and more then likely the air box ...
Results 1 to 8 of 8
    Rising Star Shooter650R's Avatar
    Apr 2008
    Rogue Canyon
    57
    151
    I realize the seat, tank, and more then likely the air box needs to be pulled off. Is there anything else I should be concerned with ?
    Ton & 1/2
    IBA# 11246
    Looking for the Double T
    I'm a free spirit .. .. ..
    Which is not understood by those who are not !
    __________________________________________
    I had no way of knowing
    Where the twists and turns where going
    But sometimes .. .. .. just got'a let the road wind.
    Rising Star SocalRancho's Avatar
    Apr 2007
    San Diego, CA
    251
    Yes, tank, and airbox.
    You need to use the tool in your tool kit under the seat to get them out, unless you have a similar tool. My socket extender wasn't long enough, and there is a weird angle. Good luck. I just did it a few weeks ago. Not quite sure how I remembered to look in the tool kit, but I did for some reason. Otherwise I would have been driving to the store.
    I love NASCAR-Go #18, 48
    2007 Blue Ninja 650R
    Suburban Machinery handlebars, R&G Tidy Tail, R&G framesliders, Scorpion exhaust w/db killer, EBC front brake pads, Barnett clutch springs, Zero Gravity dark smoke short windscreen, PCIII, DNA Air Filter, Driven USA chain/sprocket kit 15/48t blue sprocket, OEM Seat Cowl
    2007 Silver Ninja ZX-6R - Sold(wish I didn't)
    Apr 2008
    Rogue Canyon
    57
    151
    Quote Originally Posted by SocalRancho View Post
    Cool .. .. .. thanks !
    Ton & 1/2
    IBA# 11246
    Site Elder rockin_cj's Avatar
    Jun 2008
    Alberta, Canada
    787
    I wouldn't recomend using the tool kit that comes with the bike if you don't have to. Go buy a proper set, youl be happier down the road.
    Once the airbox is off you have to pull the stick coils off. Mine didn't fit with all the extenders on together, I had to take them apart, insert them one by one and then snap the wrence on, the plugs are quite recessed. Make sure you give it a quick shot of air down there to clear out most debry that may have fallen into the cylinders before you put the new ones in and make sure you torque it to spec and NO FARTHER. If you strip something down there your in trouble.
    There is a site somewhere that explains how to do this step by step as there are sensors and hoses you have to take apart, I can't for the life of me remember it though, someone else will though :P.
    Supreme Being Trubulation138's Avatar
    Jun 2008
    Ct
    1,701
    How many mile u guys changing your plugs at??
    K7 GSXR-1000-enough said.
    '07 Passion Red 650r sold in the past
    If I was concerned about gas mileage I would of bought a MOPED
    Supreme Being Compstall's Avatar
    Dec 2004
    Tacoma, WA
    43
    1,749
    After owning an LT1 Camaro for almost 9 years, I ain't afraid of nothin' (takes 3.5 hours to change plugs on them). Bring your bike over to my house and I'll knock it out for ya.
    - Brent
    '03 Z1000, gone as of 17 Oct 2011 :/
    Jun 2008
    Alberta, Canada
    787
    Quote Originally Posted by Trubulation138 View Post
    Every two years is a good estimate.
    Site Elder Phenix_Rider's Avatar
    Feb 2007
    867
    Changing the spark plugs is simple- once you GET TO THEM!
    Actually, to just change the plugs, you shouldn't have to remove the fairings. The tool in your factory kit works just fine- or you can use an extension and universal. Just remember to carefully disconnect and REconnect everything attached to the fuel tank and airbox. The fuel cap vent hose likes to slip down between the frame rails, and the main fuel hose connector WILL NOT clip completely unless the line is completely on the pump. Shouldn't be any other sensors or hoses in the way.
    I just changed mine when I did the 15k valve check. They looked new. I'll replace them again at 30k, as I don't have any other reason to tear down that far.
    '07 Ninja 650R Candy Plasma Blue
    Got Gear?
    So you think you're ready to ride? So if i ran up to you with a belt sander would you feel safe????
er6n 2012 spark plug removal
how many spark plugs does an 09 ninja 650 have
how to change spark plugs in 2007 ninja
how to change spark plugs on a 2008 kawasaki ninja 650r
ninja 650 spark plug socket
ninja 650r change spark plugs
ninja 650r spark plug change
ninja 650r spark plug removal
spark plug on 2007 650r ninja
when to change ninja 650 spark plug
