toe-toe up/down shifter + new member
This is a discussion on toe-toe up/down shifter + new member within the General Mean Streak forums, part of the Kawasaki Mean Streak category; Hi. First post. Nice to meet ya all! I'm looking for something that I could use just my toes for shifting, without having to move ...
Results 1 to 14 of 14
  • 1 Post By cbratch67
Thread: toe-toe up/down shifter + new member
    Up-And Comer brmeanstreak's Avatar
    May 2012
    47
    Hi. First post. Nice to meet ya all! I'm looking for something that I could use just my toes for shifting, without having to move my foot out to the left each time, keeping it in the same position. Here is a picture sort of showing what I mean: (perhaps it needs to be a special weld job?) thanks for info on this.
    Here is my bike in its current configuration. 12xxx miles on it; have had it for about 5 years. It is a grean 2004. couple pics below.
    Supporting Member Rasmith's Avatar
    Lenexa Kansas
    57
    5,954
    1682 times
    Nice looking bike!
    I think you'll find a limited amount of leverage at that attachment point which will make it difficult to shift. You could always install a set of boards and a Nomad heel/toe setup where the shifter is at a lower position and youre never under it.
    Where's Rasmith?
    https://spotwalla.com/tripViewer.php...a53063774d60dc
    Works best with Google Chrome or Firefox
    Supreme Being jgrazjgraz's Avatar
    Sep 2008
    2,223
    217 times
    You can remove the shifter and realign it. It has notches so you can rotate it to your fit.
    Or did you mean you wanted to add something to the shifter?
    kury grips,throttle boss,cobra pipes,chrome radiator cover,kury helmet locks,kewl risers,kury dually pegs,ghost brackets w/kawi bags,chrome side covers and chrome foot pegs,leather tank bib,swing arm cover,l&r lower frame covers,chrome inner cover.Mustang seat w/backrest,tripple whammy,Kury cruise control
    Lenexa Kansas
    57
    5,954
    1682 times
    The first picture has a rendering of what he wants to weld onto the existing shifter
    Where's Rasmith?
    Supreme Being cbratch67's Avatar
    Jun 2011
    Lubbock, The Republic of Texas
    1,641
    810 times
    If leverage is the issue you could weld from the end of the shifter arm and have the down peg 90 degrees from the shifter arm and get full value of the arm's leverage. I would make sure and leave enough from to be able to fidget your foot without changing gears by accident though...
    I have to admit that the idea appeals to me more than the heel toe.
    jtravis likes this.
    Rising Star jtravis's Avatar
    Feb 2012
    brookings, sd
    157
    34 times
    i think if your going to do it u should do it the way cbratch said, if u mount the second arm too far back u will find yourself having to push down very hard to get it to downshift. This is a great idea let us know how it works if u do it
    May 2012
    47
    wow. I never knew I could "adjust" it. sounds like it just comes off the spline and goes back on? any gaskets involved? Nothing will pour out will it it?
    -Bryce.
    May 2012
    47
    Has this ever been done? Any pictures in these forums of such a thing? I'm reading lots here... lots more than the kawasaki forum I signed up for 5 years ago. Lots more posts over here.
    Site Elder Meanie_Me's Avatar
    Mar 2009
    Western Wa
    959
    84 times
    Nope. Unscrew/loosen the bolt at the bottom if the lever, wiggle the lever off and put it back on at a more preferable angle and retighten.
    ______
    Tapatalk 2, yo!
    Nothing makes you feel more alive than taking a bee to the face at 60 mph.. Shortie helmets rock!!
    2003 Meanie
    Lenexa Kansas
    57
    5,954
    1682 times
    Quote Originally Posted by brmeanstreak View Post
    You'll need to take the peg bracket off..(couple bolts) then one bolt on the shift lever and slide off the spline shaft..(hint..use a punch to mark the original position on the shaft so you can go back)
    If I were you, I would cruise EBAY for a used shift lever and experiment on that.
    Where's Rasmith?
    May 2012
    47
    Is there an actual model number on a shift lever I need to look out for? This sounds like a good idea.
    Rising Star pauly75's Avatar
    Nov 2006
    Fort Atkinson, WI
    458
    71 times
    Not sure of the actual number, but here is one. $40 seems kinda steep to me though.
    Kawasaki Mean Streak VN 1600 Shifter Shift Pedal Lever | eBay
    Cheaper one
    KAWASAKI VN1600 VN 1600 VULCAN MEAN STREAK SHIFTER 2004 | eBay
    2005 MS
    PCIII, Jardine FC's, Mustang Seat, Jardine Sissy Bar/Luggage Rack, Memphis Shades Batwing
    May 2012
    47
    At least I know what I'm looking for now though... thanks!
    Jun 2011
    1,641
    810 times
    You could also look for the shift lever off of the Marauder 1600 or the M95
2003 vulcan nomad heel toe shifter
2004 kawasaki meanstreak shifter arm
can you extend the gearshift on a 2007 kawasaki mean streak
heel toe shifter for kawasaki mean streak 1600
kawasaki mean streak heel toe shifter
kawasaki meanstreak shifter lever
kawasaki nomad toe shifter
kawasaki vulcan 1600 gear shifter lever set
remove heel toe shifter vulcan nomad
shifter adjustment on 2003 vulcan mean streak
