Reed Valve Block Off Plate INstall
This is a discussion on Reed Valve Block Off Plate INstall within the General Mean Streak forums, part of the Kawasaki Mean Streak category; So I did the reed valve block off plate install today... http://www.gadgetjq.com/rv_removal.htm # 6 says follow the vacuum hose and remove it (1500's only) from ...
Results 1 to 15 of 27
Like Tree3Likes
Thread: Reed Valve Block Off Plate INstall
    Site Elder regnaston's Avatar
    Mar 2010
    Whitby, On
    780
    16 times
    # 6 says follow the vacuum hose and remove it (1500's only) from the carb/throttle body.. and cap the opening where the hose went into..
    I did not have a cap, and I did not feel like removing the tank and trying to get the hose off the throttle body, so instead with the tank tipped, I ran the hose up so it was sticking above the frame under the tank... I took a golf tee, and forced it into the hose It took alot of effort) and then tie wrapped the hose around the tee... I then reinstalled the gas tank, and the hose is no longer visible
    I think this provides the same 'blocking' as blocking thye nub at the engine... what do you guys think?
    2002 Kawasaki Mean Streak vn1500
    - Samson Warlord RipSaw Exhaust - Driver Kuryakyn Swingwing Pegs - Passenger O-Ring Pegs - Arlen Ness Chrome Rectifier Cover -Mapam Chrome Rad Cover - Kuryakyn ISO Grips - Billet Oil Cap - Corbin Rumble Seat - Kuryakyn Brake Pedal Cover (4045) and Shifter cover - Clear Alternatives Integrated Tail/Signal Lights - Mikeg Horizontal sidemount License plate bracket - Spike Air Intake - Dynojet PC III
    Jan 2007
    South
    3,796
    762 times
    Well if you used the plates then the air aint going into the exhaust anymore. If you didn't remove the actual module under the tank then it'll still try to pump but it just won't go anywhere. I ripped all of it out and put electrical tape on the 2 connectors. The cap on the throttle body was for the carb'd versions. On our FI bikes the plug goes on the back of the air cleaner backing plate. You plug it so unfiltered air doesn't get inside the engine.
    Jan 2007
    South
    3,796
    762 times
    The red arrow
    Mar 2010
    Whitby, On
    780
    16 times
    Actually the 1500 is different than the 1600 (I think)
    There is a small diameter hose (about the same diameter as used on a fish tank air bubble compressor).. that comes off that unit under the tank (which I did remove) and into the throttle body.... Instead of removing that small hose, I left it attached to the throttle body and just plugged the one end.. All the other plumbing is gone
    The hose in your picture isn't that the crank case vent hose?? That was not attached to the unit the reed valves were connected to on mine, but goes into the front side of the engine near the bottom left side
    Mar 2010
    Whitby, On
    780
    16 times
    #19 is the hose I am referring to
    Jan 2007
    South
    3,796
    762 times
    It was a long time ago, can't remember. I don't recall plugging anything other than the backing plate but I've got the 1600. The 1500 fiche does look like there's something extra there.
    Site Elder Nyinfamous2k2's Avatar
    Oct 2010
    NY
    901
    260 times
    I have a 1500 also
    did you just install an intake, because there is a smaller hose that gets pluged back into the new intake, I also have the larger hose on mine and capped it off, which looks like #6 and the red arrow in the two pics.
    , 200/55 Avon cobra rear, 130/70 Avon storm front, sickle mirrors, ToyTech license plate mount, Progressive 444 shocks, spike intake, PC3, chrome spike grips, chrome bullet rear signals, chrome passanger pegs, chrome master cyl & brake res cover & switch housings, + other minor chrome parts. MassMax V-stream windshield.
    Mar 2010
    Whitby, On
    780
    16 times
    I did install the Woody Mod
    http://www.gadgetjq.com/wood_intake.htm
    If you look through that, the only hose that goes into the backing plate is the crank case vent hose.. It is smaller diameter than /6 (IIRC).. the Crank Case Vent hose actually runs near the assembly above but is not attached to it.. The Reed Valve near the fan has a clip attached to the top bolt to hold the CC Vent hose in place
    The CC Vent Hose attaches near the bottom of the front cylinder
    Supporting Member Rasmith's Avatar
    Lenexa Kansas
    57
    5,954
    1683 times
    Quote Originally Posted by streak07 View Post
    The red arrow
    Too funny..I've been chasing down a backfire issue and KNEW I had everything done correctly last year..This year it started backfiring. I had a plastic plug in the tube with the red arrow..Today I pulled everything apart and found the plug had cracked in half, no clue how. I'm sure glad I didn't pull the exhaust off looking for cracks or bad gaskets. Nice Pic BTW
    Where's Rasmith?
    https://spotwalla.com/tripViewer.php...a53063774d60dc
    Works best with Google Chrome or Firefox
    Mar 2010
    Whitby, On
    780
    16 times
    I checked the old thread that I made for the woody Mod.. and I was wrong when I said that top hose was the CCVH it does go to the Reed Valves
    http://www.riderforums.com/showthrea...elp&highlight=
    The hose at the bottom (see pic on link) is the CCVH
    Rising Star alexpen77's Avatar
    Apr 2012
    Tampa
    346
    51 times
    help
    I know this is an old thread but i can't find and answer on any other, so here is my dilemma ... i decided to remove the reed valves and while removing the plumbing according to the instructions i ran into a hose that says to be removed #6 to be more specific, however that leaves a hole at the crankcase... what to do plug the hole, leave the hose(rather ugly with everything else removed)IMG_2006.jpgIMG_2007.jpg
    AP
    04 VTX 1300C - Sold
    06 Ninja 636 - Sold
    Custom Chopper Rigid - Stolen...
    08 Yami R6 - Traded
    10 GSXR1000 - Totalled
    06 Meanstreak Lowered rear 11" ,Low and Mean Reaper rear Fender, Low and Mean CRS, Cobra Exhaust, Fi 2000, Kuryakyn Universal premium ISO-Grips, Spike Forced air intake, HID 10K, LED front turn signal, LED turn/Running/brake lights rear, Mirrors, forward controls... Soon to have 7*or 8* triple tree, wide wheel, 200 tire, and many more
    Lenexa Kansas
    57
    5,954
    1683 times
    Quote Originally Posted by alexpen77 View Post
    Thats a great place to put an oil breather filter.
    Steammaker likes this.
    Where's Rasmith?
    Up-And Comer JRod's Avatar
    May 2011
    Napa, CA
    147
    47 times
    oh son of a b!tch!
    when i ordered the barons big air kit it came with the reed block off plates
    there wasnt any paperwork in the kit refering to them and i didnt know what they were so i threw them away!
    damn it, damn it, damn it
    now i want to order some........
    lee
    lee is offline
    Supreme Being lee's Avatar
    Dec 2011
    Lancaster, CA
    2,566
    1319 times
    Baron Custom Accessories Reed Valve Block-Off Plates, Vulcan 1500's/1600, offhand. It mentions the 1500 Mean Streak but not the 1600 specifically.
    Steammaker's Avatar
    Apr 2011
    Cincinnati, Ohio
    2,722
    1196 times
    Quote Originally Posted by Rasmith View Post
    Good idea rasmith. I have a filter on there BUT, now It hit me that I can shorten that hose
    & put the filter on the front of the motor. I'm glad I read this thread...
    I'm addicted to Modifying my Meany!
    The Original Meanbagger
    Built, balanced, polished & ported Motor by Speed
    PC III
    BAD ACE Intake
    True Dual exhaust
    Mustang seat w/Custom World backrest
    Lindby guard w/highway pegs
    14" apes & SS lines
    WOLO Horn
    Shark sound sys.
    Memphis Batwing
    L&M chin scoop
    Matazu hardbags
    Custom Candy metallic paint
    with Ghost Flames
    "Vulcan Classic" rear fender
block offs on a 1500 kawasaki
kawasaki mean streak reed block off
kawasaki reed block off
kawasaki vulcan 1500 reed petal
kawasaki vulcan reed valve block off
mean streak reed valve block off plates
reed block off plates mean streak
vulcan 1500 block off plate
