Crank Case Breather???
This is a discussion on Crank Case Breather??? within the General Mean Streak forums, part of the Kawasaki Mean Streak category; A buddy of mine installed a Crank Case Breather on his Meanie.. (See attached picture).. Just curious what is the purpose of relocating the Crankcase ...
Results 1 to 15 of 21
    Site Elder regnaston's Avatar
    Mar 2010
    Whitby, On
    780
    16 times
    A buddy of mine installed a Crank Case Breather on his Meanie.. (See attached picture).. Just curious what is the purpose of relocating the Crankcase vent??
    2002 Kawasaki Mean Streak vn1500
    - Samson Warlord RipSaw Exhaust - Driver Kuryakyn Swingwing Pegs - Passenger O-Ring Pegs - Arlen Ness Chrome Rectifier Cover -Mapam Chrome Rad Cover - Kuryakyn ISO Grips - Billet Oil Cap - Corbin Rumble Seat - Kuryakyn Brake Pedal Cover (4045) and Shifter cover - Clear Alternatives Integrated Tail/Signal Lights - Mikeg Horizontal sidemount License plate bracket - Spike Air Intake - Dynojet PC III
    Site Elder DreamStreak's Avatar
    Nov 2006
    Hiram, GA
    43
    998
    18 times
    I'm guessing he thought it looked good, but it is not as functional as the stock set up because the stock set up uses vacuum from the intake to help evacuate the crankcase where what he has is just a vent, but serves it's purpose in keeping pressure from building in the crankcase and blowing seals, etc.
    2006 Mean Streak
    Muzzy Big Bore Kit
    Thunder Cams
    Heads Ported by Me
    Intake Ported by Thunder Manufacturing
    PCIII-Custom Map
    Forcewinder Air Intake
    Muzzy 2 into 1 Megaphone Exhaust
    Reed Valve Block Off Plates
    Mustang Seat, Fender Bib, & Tank Bib
    Jardine Forward Controls with mini floorboards
    Kuryakyn ISO Grips with Stilletto ends
    Site Elder rbthntr64's Avatar
    May 2010
    Show-Me State
    597
    When you remove the reed valves, the crankcase breather is part of that system. It has to go somewhere. I have mine up by the "choke" Throttle up knob.
    Nov 2006
    Hiram, GA
    43
    998
    18 times
    Quote Originally Posted by rbthntr64 View Post
    No it isn't. There is no crankcase "breather". It is a crankcase evacuation hose that goes from the crankcase to the air intake. I have my reed valves removed and still use the original crankcase evacuation hose.
    2006 Mean Streak
    Muzzy Big Bore Kit
    Thunder Cams
    Heads Ported by Me
    PCIII-Custom Map
    Jan 2007
    South
    3,798
    762 times
    Yup. And normally you try to mount it higher to reduce the risk of losing oil out of it. Typically at or above the heads to reduce blow-by. Stock is right at the bottom of the heads but the bike doesn't rev past 6k rpm and doesn't see a lot of crankcase pressure like in forced induction which is where it tends to get worse. I don't see the point unless you want more chrome or you're seeing a lot of oil in the intake area.
    May 2010
    Show-Me State
    597
    Quote Originally Posted by DreamStreak View Post
    OK, maybe not techically a "breather", But mine ran up the front of the engine, over the top to a valve that ran to the reeds and to the intake. Got rid of alot of extra crap that is no longer necessary with my configuration.
    Riding in honor of my Dad.
    Jan 2007
    South
    3,798
    762 times
    Thats the air intake to the reed valve system and why marbling will disable it. The breather tube should still be there and is separate.
    May 2010
    Show-Me State
    597
    I'll pull my tank when I get home and take a pic. Not sure if the 1600 is the same configuration as the 1500, and standard to Kalifornia compliant ones. There was only one hose from the front of the engine, two that split off to the reeds, and one that ran to the AIS crap. Four total, NO MAS!
    Supreme Being speedracer's Avatar
    Jul 2007
    8,985
    5238 times
    got to see this.
    Up-And Comer Ranger's Avatar
    Puerto Rico
    45
    Howdy hey Streak07 and DreamStreak just to make sure I don't mess anything up, I can go ahead and disconnect the reeds without risking overpressure at the crank correct? I have not had the need to do it yet since I am undicided about what intake to install but would like to be rid of them noisy critters nevertheless, intake or not.
    Nov 2006
    Hiram, GA
    43
    998
    18 times
    You can take the reed valves off without worry. The reed valves are not noisy by themselves, but will cause popping/backfiring out the exhaust with aftermarket pipes (does it with stock pipes too, but the stock exhaust muffles that sound). You aren't talking about the idle control solenoids are you? They are under the right side intake cover, noisy, and usually disabled when adding an aftermarket intake.
    2006 Mean Streak
    Muzzy Big Bore Kit
    Thunder Cams
    Heads Ported by Me
    PCIII-Custom Map
    Puerto Rico
    45
    DreamStreak I do believe you nailed it, they are inded the idle control selenoids and you are absolutely correct about the noise they make specially when sitting at idle or coasting along at lower speeds since there is not enough wind or exhaust noise to cover it up. Since I am not modifying the intake to a cadmann or aftermarket for the time being, can I still be rid of those? I was well on the way to doing so before the crank breather subject came up and left me doubting wether or not I can do the one without the other (Disconnecting without new intake). Being new to the Meannie I place my trust on you (You guys know your stuff) rather than taking a guess and have things go haywire. Thanks for the help.
    Supporting Member Rasmith's Avatar
    Lenexa Kansas
    57
    5,954
    1684 times
    Quote Originally Posted by Ranger View Post
    I took 2 fuel resistant hoses about 8" each in length, put one on each of the outlets of the solenoids then stuck them in the crossover tube..All the noise vents in there and took 98% of the noise away..Considering you're in a warm climate, I believe you can get away with eliminating the solenoids all together..The hoses are the quick and dirty method though
    Where's Rasmith?
    https://spotwalla.com/tripViewer.php...a53063774d60dc
    Works best with Google Chrome or Firefox
    Supreme Being madperson's Avatar
    Jan 2009
    Chesterfield, Virginia
    1,615
    716 times
    Rasmith, Just trying to put 2 and 2 together here! Are you running a stock intake set up? If so go back to the thread on the $40 dyno. I believe something was causing a rich mixture! Maybe it's because you have blocked probably a third of your air intake on an already restricted system. It might be part of your problem.
    Madperson (AKA Teddy Bear)
    2008 Mean Streak SE Memphis Shades Shield, MM angled risers, Leatherlyke Bags, Arlen Ness Rad 3 mirrors (black), Mapam forwards (black) with swing wing pegs, ISO flame grips with throttle boss, Hard Krome exhaust w/tips, Mustang Seat, PCIII, Spike Intake, luggage rack. 2 configurations when I'm done one as a solo, the other as a tourer.
    Lenexa Kansas
    57
    5,954
    1684 times
    Quote Originally Posted by madperson View Post
    lol..No I was only rich on idle..THen when I cobbed the throttle it went lean and took a while to recover because I had the 2nd pot too low.
    I now have the PC3 in and have been playing with maps..Found a good one and put in the accelerator pump..very sweet!!!
    I have absolutley no air restrictions..Check out the pics below..
    Where's Rasmith?
05 mean streak air breather
bandit crankcase breather kit
chrome crankcase breather
mean streak crankcase pressure
muzzy crankcase breather
purpose of crankcase breather
vn1500 faring
what is a crankcase breather
what is the purpose of a crankcase breather
what is the purpose of crankcase breather
