For touring: Bell Universal Water Bottle Mount & Cage
This is a discussion on For touring: Bell Universal Water Bottle Mount & Cage within the General Mean Streak forums, part of the Kawasaki Mean Streak category; Hi all, Wanted to run this by you: I bought this at my local Wal-Mart for $6.48 (+tax). It's a standard aluminum cage with a ...
Results 1 to 15 of 30
    Rising Star Erdejo's Avatar
    Jan 2009
    Mobile, AL
    254
    Hi all,
    I bought this at my local Wal-Mart for $6.48 (+tax). It's a standard aluminum cage with a handle bar mount. The range of tubing mentioned is 22.2-28.6mm (0.87” – 1.126”). This mount can only be horizontal or vertical, with nothing in-between. It comes with a piece of rubber to protect the frame/handle bars from scratches.
    The UPC is 035011887296. I have not seen this for sale on any web site.
    Another advantage of this mount is that by removing the two little screws (see image in red circles) you can remove the “big” aluminum cage but leave the mount on the bars without them being too obvious.
    See the attached pic....
    Later, Eric
    2002 Red Mean Streak with too many add-ons to mention. Some are listed in the following thread: http://www.riderforums.com/showthrea...25548&page=113 ,(starting with post #1687). There are also some pics there......
    More Mean Streak specific sites: Meanriders and Meanieforums.
    El Cajon, Ca.
    12,766
    10 times
    I have something similar and it works just fine. Just remember that you you need the "sports cap" on water bottles so you can open and close it with your teeth while your riding.
    Up-And Comer MeanShark's Avatar
    Apr 2008
    Mountains in Oregon
    134
    Or get a really long straw. LOL
    Supreme Being timdull2's Avatar
    Jan 2009
    Johnstown, PA
    1,570
    Neat idea! I never thought of that!
    Now, to figure out how to get a sport bottle full of Starbucks coffee into my mouth through my Icon Airframe.... lol
    President 1-17 Laurel Highlands VRA
    www.lhvra.org
    08 SE - the Wicked Streak!
    Fuggin Hellions
    De-badged, replaced with 'badge of honor'
    WCC Spikes on axle, shocks, radiator, steering nut
    Kawa Sissy
    Custom Side Plate Mt.
    "WCKD1" plate
    Funk-ay mirrrs
    Custom Dynamics Int. Rear
    Custom Flame Frame Plates
    Custom Mean Riders Rad. Cover
    Kury Wide Levers - Black Powdered
    Stingerz Lava LEDs (192) + Remote
    Black Spike Grips & Barsnake
    Custom 'Flamed' Seat
    Supreme Being troop's Avatar
    Oct 2003
    1,556
    I've been using a Walmart water bottle mount for years. I used one pre-existing hole, drilled another and just used longer bolts/spacers on my left side mirror/resevoir mount. Very convenient for long rides...
    Thunder Tornado intake
    PCIII/Custom map
    Muzzy 2-1 meg exhaust
    Jan 2007
    Sandbox
    2,940
    79 times
    I got a 2 ball RAM mount attached onto the 2 bolts for the mirror. One I use for my GPS and another for a drink holder. If I'm not going anywhere far the stuff comes off with only the mount left, can't even notice it there.
    Up-And Comer audionutmike's Avatar
    Mar 2009
    Gilbert, AZ
    39
    75
    I guess I'm a nerd...I just use a camelpack, plus I can stow a few other things with it and I don't have to have something mounted to my meanie.
    DG Hard Krome Strippers
    Debadged
    Kawasaki two up seat
    Cobra mini back rest w/ wide pad
    Mobile 1 oil
    K & N Filter
    Power Commander
    Woody Intake Complete IAC's mounted under tank
    Baron's block off plates
    Custom run/turn/brake LEDs
    Metric Phats stealth turns
    custom (home made) vertical side license plate
    Meguiar's Car Care products ONLY
    on the way:
    Braided brake lines / throttle cables
    I'm sure something else will come up!
    The power of the Meanie compels you!
    Rising Star SgtDan's Avatar
    Mar 2008
    Menomonie,WI
    31
    225
    +1 for camelpack
    Life is hard it is even harder if you are stupid.
    John Wayne
    Oct 2003
    1,556
    Quote Originally Posted by audionutmike View Post
    The make shift Wallyworld holder goes off/on with two bolt changes, about three minutes if you're slow. I guess I find that more convenient than strapping another piece of gear onto my body ???
    PCIII/Custom map
    Jan 2009
    Mobile, AL
    254
    There you go.....
    Quote Originally Posted by troop View Post
    Exactly Troop,
    That's why I got it. I know there are other ways of doing it (for instance look at Gadget's page) but that's all "Mickey Mousing" stuff together. This is a ready made solution that works perfectly fine with our stock handle bars. It takes about 5 minutes to put the whole thing on from scratch and then after that is taking out or putting in the two little screws. After taking the holder off the mount, screw the little screws back into the mount and you don't even have to worry about loosing the screws.....!
    I want to have as little junk strapped to my body as possible...... makes for a much more comfortable ride!
    Eric
    Rising Star Minker's Avatar
    Mar 2009
    Ottawa, Ontario, Canada
    193
    ...man why is everyone in such a hurry, I stop, buy a drink at the corner store have a smoke....chill...out ...a while!!!!LOL!
    Jardine Forward Controls
    V&H Straight Shots
    Kuryakyn Hypercharger
    PCIII
    Memphise Shade
    Chrome Rad Cover
    Chrome Control Covers
    Progressive Front Springs
    VROC # 7742
    http://photobucket.com/minkers
    Oct 2003
    1,556
    Quote Originally Posted by Minker View Post
    I like stopping too but I appreciate the water holder, especially like my last Sturgis trip when it was 100 degrees and 125 miles between fuel...
    PCIII/Custom map
    Rising Star Tuff's Avatar
    Jul 2008
    183
    +1
    the way i see it is your on your bike to ride it
    Am i wrong? LOL
    When i am thirsty i will stop for a drink.
    When i am dead i will quit riding my bike LOL
    To me theres no use in complicating things.
    If i wanted the convienences of a gold wing type bike i would have bought one.
    Just my
    www.meanieforums.com= Up and Running!!!
    Rising Star jannix's Avatar
    Jan 2009
    Santa Clara, CA
    29
    181
    I think a water holder is actually quite useful. I did a few long trips recently. One was a 900 mile in a day followed by 1 day of exploring the area and 900 miles the day after. (Was aiming for a 1000 but I had it after 900)
    Anyways, keeping yourself hydrated with plain ol' water seems to be one of the biggest tips from experienced "iron butt" style riders. On my way back, I tried to do so and I noticed significantly lower leg cramps at the end of the ride.
    Besides, on long trips, you really do need to watch how much time you spend on breaks and keep it to the minimum. So an easy access water bottle sounds like a really great idea, and inexpensive too!
    2005 Suzuki GSX-R 1000 : Bone stock other than frame sliders, Bremo brake master cylinder, braided lines and some carbon fiber bits here and there.
    Jan 2009
    Mobile, AL
    254
    Stopping......
    Hey Minker,
    I fully understand where you're coming from.... But since I quit smoking about ten (10) years ago that takes away one reason for me to stop.
    And since I have a wife and two (2) younger (12 + 10) children, I do not have the time to stop anymore and I need all the time I can get on the bike before I have to head home again as to not p.o. the wife too much........
    So as many miles as I can can without stopping here in Mobile (where it can and does easily get 100+ degrees with 100% humidity) I need my fluids.......how ever much I can!
    But again, to each his own preference. I just posted it for those of us that are thirsty while on the road.....
    Eric
bell bottle holder
bell sports, inc. universal water bottle mount & cage
bell universal
bell universal water bottle mount
bell universal water bottle mount & cage
bell universal water bottle mount & cage instructions
bell universal water bottle mount and cage
bell water bottle cage instructions
bell water bottle mount
bell water bottle mount and cage
how to install a bell universal water bottle mount and cage
how to install bell universal water bottle mount
how to install bell universal water bottle mount and cage
how to install bell water bottle cage
how to install bell water bottle holder
