Bandit 1250 maintenance & reliability
This is a discussion on Bandit 1250 maintenance & reliability within the General Bandit Chat forums, part of the Suzuki Bandit Forum category; I am looking at buying a used 2007-2009 1250 bandit. I assume the bike is reliable if it has been well maintained. Could you guys ...
Results 1 to 9 of 9
    Newbie Secca's Avatar
    Oct 2011
    I am looking at buying a used 2007-2009 1250 bandit. I assume the bike is reliable if it has been well maintained. Could you guys confirm.
    What type of maintenance can I expect: intervals between valve adjustments, oil changes, replacing the chain...
    Thank you.
    Up-And Comer KiwiBandit's Avatar
    Apr 2009
    New Zealand
    54
    I've put 42,000ks on my 09 1250 with just oil changes, tyres, chains and not much else at all ... A friend had a 1200 - he was a motorcycle mechanic - he did the same, but did once change the plugs - last heard of he had 140,000klicks on it witout a spanner on the engine apart from plugs and oil drain ...
    Owner of a 2005 GSF650 Bandit, and a 2009 GSF1250S Bandit
    Oct 2011
    Thank you for the reply. I was under the impression that valve adjustments were needed every 5-7K miles. Is this a myth?
    Apr 2009
    New Zealand
    54
    From my expereince it's a myth .. My 650 is starting to rattle a tad - at 42,000ks ... it is probably the valves ... but that's way more than every 5-7 ... and I play on the 650 much harder than I do on the 1250 ..
    Up-And Comer stratochile's Avatar
    Jul 2011
    oshkosh wi
    29
    sold
    Apr 2009
    New Zealand
    54
    Bugga !!! At 32,000ks my 1250 needed a new fork seal .. it was leaking a little (replaced both) ... that's the first repair of any kind it's needed!!!
    Rising Star Hugo Delgadillo's Avatar
    Apr 2004
    Mulberry, FL, USA
    63
    356
    What manuals recommend is 'Valve Checks' at certain intervals, not valve adjustments, which may or not be needed.
    Newbie geoboy's Avatar
    May 2011
    8
    Quote Originally Posted by Secca View Post
    Per the users manual:
    Valve check interval: 14,500 miles
    Oil change: 3,500 miles
    Newbie Harry 'O's Avatar
    Dec 2011
    4
    Good to know since I don't have an owners manual.
1250 bandit forum
2009 suzuki bandit service intervals
bandit 1250 forum
bandit 1250 forums
suzuki 1250 bandit forums
suzuki 1250 bandit reliability
suzuki 1250fa service intervals
suzuki bandit 1250 forum
suzuki bandit 1250 service intervals
suzuki bandit 1250 valve adjustment
