What are symptoms of weak ignition coil?
This is a discussion on What are symptoms of weak ignition coil? within the General Bandit Chat forums, part of the Suzuki Bandit Forum category; I have an 02 bandit 1200 with 21,000 miles. It had been running just fine until one day it started acting if it was running ...
Results 1 to 8 of 8
    Newbie jonnyrotton's Avatar
    Aug 2011
    8
    I have an 02 bandit 1200 with 21,000 miles. It had been running just fine until one day it started acting if it was running out of gas anytime the throttle was turned from 1/2-full throttle(it would still rev). I cleaned out the carbs did a holeshot stage 1 jet kit. That seemed to cure the problem about 65-70%. But I only rode it once after the carb work( i also adjusted the valves and tps plus put new plugs in)then rode it today and the bike acted as if i never did anything to it. It almost seems as if it is firing on 3 cylinders instead of four or something. Is it even possible to only fire on three instead of four? And how about all four firing but maybe two cylinders firing weak. This problem has me wanting to fix it with sticks of dinamite and its in great shape!
    Rising Star Suzooker's Avatar
    Jun 2008
    251
    http://www.youtube.com/watch?v=UxcO9d9FATs
    You should be able to check the coil's resistance using an ohmmeter. First, find out what the resistance should be by looking it up in the bike's service manual. Then, compare that reading to the actual reading taken on the coil itself. If it doesn't fall within the acceptable range stated in the manual, replace the coil. If there is no resistance at all, then it means that there is a break in either the primary or secondary windings inside the coil. Breaks are not repairable and the coil again must be replaced. Also, plug wires can be checked for proper resistance using an ohmeter. Hope this helps.
    Aug 2011
    8
    Is my thinking correct on how to check the ohm's? I would say check ohms on the "power" side of coil between the 2 electrical tabs. Then check the ohms on the "spark" side between the 2 spark plug wires?
    Site Elder aodrn's Avatar
    Sep 2010
    St. Louis
    749
    http://www.aa1car.com/library/reading_spark_plugs.jpg
    Your spark plug will probably look ashy like in this diagram
    Full 636 supension swap. -1 front sprocket. Zx10R throttlebodies. Akra full exhaust. PC3. Adjustable ignition advance. The Force
    Aug 2011
    8
    The thing is, is that it was doing all this before I put new spark plugs in and they looked normal. It definately seemed to be a fueling problem at first, but since I changed the main and pilot jet and that seemed to cure 65-70% of the problem I was pretty sure I was going in the right direction. But starting it up while waiting for my midrange jets to come in, it starting acting very strange again. I would say even worse than the first time and slightly different, seemed to be missing a little if trying to rev it. So thats what got me to wondering if it was never even the carbs but the ignition system. But why the hell would rejetting do anything good that first day.
    Up-And Comer gegkx85's Avatar
    Jul 2011
    orlando florida
    83
    hey man , i'm having similar problems.Bike lost power , and mis fires under load usually in the higher rpms... have you figured it out??
    anything with wheels...
    Newbie Paddy's Avatar
    Jun 2013
    did you ever sort it out ? my '98 1200 is doing the same, I changed out the coil packs, new fuel line, new plugs and still its like its being starved of fuel, but as it heats up a bit it gets a bit better but when taking off in 1st it's like it going to cut ou... it ticks over fine... driving me mental... help
    Jun 2013
    I had the same problem as I have said before but no I took the carbs off and cleaned out the pilot jets and balanced them too and now its 100%...
bad ignition coil symptoms harley
motorcycle ignition coil failure symptoms
suzuki ignition coil problems
symptoms of a weak coil
symptoms of bad coil on motorcycle
symptoms of weak spark
weak ignition coil symptoms
weak spark symptoms motorcycle
what ca cause weak spark
