Adjusting Bandit suspension
This is a discussion on Adjusting Bandit suspension within the General Bandit Chat forums, part of the Suzuki Bandit Forum category; I have tried to adjust spring setting on rear shok (1250K8) but find there is no room to get leverage on tool. Anyone tell me ...
Results 1 to 9 of 9
    Newbie mbmrider's Avatar
    Feb 2008
    UK
    16
    I have tried to adjust spring setting on rear shok (1250K8) but find there is no room to get leverage on tool. Anyone tell me how this is done? Should be a 5 min job, right?
    Up-And Comer Jack Bauer's Avatar
    Oct 2007
    SoCal
    41
    I'd answer your question but I don't have the bike to look at. I did look in the shop manual, but it only gives the settings. What does the owners manual say?
    Feb 2008
    UK
    16
    Quote Originally Posted by Jack Bauer View Post
    Thanks Jack. It just shows the use of the supplied spanner on the shock, but if you try to access it, there's no room to pull on the tool before it hits the frame. Plus it requires 2 hands by the feel of resistance, but there's no room. So far I have left it on factory setting - which is fine for 2 up, but hard for solo. So much for a single shock design..
    Up-And Comer El Bandito's Avatar
    Sep 2007
    Lancaster CA.
    110
    Quote Originally Posted by mbmrider View Post
    The preload can be adjusted with the spanner wrench and slip on handle found in the tool kit, but if you find theres not enough room for you, I suggest that you remove the black plastic splash guard that temporarily attaches to the bottom of the rear fender, just behind the rear shock. Its held on with (2) 6mm screws and (2) plastic self tapping phillips head screws, and it blocks easy access to the preload adjuster.
    You also need to do any preload adjustments with the bike up on the center stand so that you do not have the weight of the bike sitting on the rar suspension while you are trying to adjust the shock.
    Custom Candy Sonoma Red 07 Bandit 1250S
    www.metrickmetal.com
    Supreme Being Pete's Avatar
    May 2003
    UK
    1,012
    I too found the rear suspension standard setting too hard for solo use and failed to adjust the setting due to such restricted access. I took the bike back to the dealers and their head mechanic adjusted it for me but not without catching the frame! He also agreed that he found the standard setting too hard. I beleive the standard setting for the unfaired version is one lower than for the GSF1250SA model.
    I have since changed the rear shock for a Hagon replacement complete with a remote preload adjuster
    Pete
    Oct 2007
    SoCal
    41
    For those without a shop manual:
    Spring Preload:
    Position 1 is softest, thru 7 (firmest)
    STD Position:
    1250a: 3rd position
    1250s/sa 4th position
    Damping Force:
    Clockwise to stiffen, CCW to soften.
    STD position: 1.25 turns FROM STIFFEST position
    Feb 2008
    UK
    16
    Quote Originally Posted by El Bandito View Post
    Thanks for that - I will try it. It definitely needs lowering for solo riding.
    May 2003
    UK
    1,012
    Watch your knuckles
    Pete
    Newbie vabenni's Avatar
    May 2008
    8
    I adjusted the the pre-load yesterday with the spanner tool. It is a bit tight but it can be done. The wrench pops off after it clicks a notch. That said, My ride to work to day was much better. Felt pretty comfy on the tail bone. After adding the larger windscreen and a softer seat I can see doing a few miles on it. ( I put it on '1')
adjusting rear shock to be firmer bandit 600s
bandit 1250 suspension settings
bandit suspension
front shock adjustment on suzuki bandit 1200
how to adjust ride height on suzuki bandit 600
how to adjust suspension on a suzuki bandit 1250
how to adjust the height on 2007 suzuki bandit 1250
suzuki bandit 1200 suspension adjustment per rider weight
suzuki bandit 1250 rear shock adjustment
suzuki bandit 600 suspension adjustment
