How do you remove stock tail section on Ninja 1000 (for tail tidy)
This is a discussion on How do you remove stock tail section on Ninja 1000 (for tail tidy) within the 3rd Gen Z1000/Z1000SX/Ninja 1000 forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; EDIT POST - it's all done now, figured it all out thanks to "haknslash's" video!
I'm installing a tidy tail on my Ninja 1000. I've ...
Site Elder
I'm installing a tidy tail on my Ninja 1000. I've removed the four bolts going down into the stock tail piece from under the rear seat and I'm having no success getting it off. I don't see any more screws and I've tried everything I can without risking breaking it. I'll do a search here and keep working on it, but I'm sure within 30 minutes someone can provide me the easy answer (no pressure!!!).
Thanks
2011 Ninja 1000 - 2012 Ducati Panigale ABS - 2013 BMW 1600GT
08-24-12 04:15 PM
Site Elder
I just found "haknslash's" video - YOU DA MAN
R&G leaves out very important steps for the N1K. Back out to the garage.
Site Elder
How in gods earth did they manage to hide those two phillips screws? And why?????? LOL
Quit working in the dark!
Power without perception is virtually useless
Go real fast turn ta da left!!!
Site Elder
Once I saw that the grab handles had to be removed and drop down the entire rear fender to get to those two screws it all came together (the instructions said nothing about that). I got everything together about an hour ago when my wife called me in for dinner. I'm just trying to figure out which way to route the wires. The cut out in the gasket they supply seems like they want you to route the wires differently than stock. I'll figure out the best way to do that and should have it all back together in about 30 minutes. All the wiring is done and everything is working.
BTW, I guess I didn't mention I have the R&G kit. Did I mention that their instructions suck the big one if you have a Ninja 1000?
Site Elder
Got it all done. But not before one of the bigger "WTF" moments in a very long time. I got everything together, double and triple checked the lights were all working, even had the seat back on the bike and just had to bolt the license plate to the new tidy tail. Ummmmmm, what am I doing wrong here - must be missing something obvious. No, no, no, no.... The license plate will not mount because the license plate light (that came with the kit) interferes with the top of the license plate itself. After about ten minutes of mulling what I might have done wrong (nothing) I took a large screw driver and bent the outer parts of the tidy tail bracket down and was able to get the top of the license plate partially under the light. I have no idea what they were thinking. I looked in the package to see if there was some sort of bracket to mount the plate down lower, but there was not, nor should there have been a need for one. But it's all on and looks good now, but just out of spite for a company that does stupid sh*t like that I would have a hard time recommending the R&G.
Yup, sounds like my exact experience as well. Nothing like telling your wife "yup, I'll be done in an hour" only to realize an hour later you aren't done. Sound familiar?
My challenge was routing the wires up through the subframe, unable to get the tail tidy to sit tight to the undertail. There is a specific way they need to be routed and turned so they don't prevent the undertail from sitting flush with the sub frame. One of the the ****tiest mods I have done to any of the 14 bikes I've owned.
Site Elder
Cooldaddygroove
I forgot to mention, I had to use longer bolts on the front two than what came with the kit. I was concerned it might be because I didn't have it seated right. In fact, I actually plan to go back and try the ones that came with the kit. I think when I got it all buttoned up I may have gotten everything seated right, but I'm still not positive. But it does seem okay. Thanks for confirming that it wasn't just me!
Site Elder
My Muzzys tail tidy went right on, no problems, but instructions were horrible as well. A kick to the groin for whomever decided to keep those two screws secret.
2012 Ninja 1000 ABS - Metallic Spark Black/Metallic Flat Micron Gray
GiPro-DS gear indicator in white ° OEM Ninja gel seat ° TRS/Morimoto 5000k HID ° superbrightleds.com 5500k SMD LED marker lights ° Tankslapper film ° R&G fender eliminator
Site Elder
haknslash
Glad the video helped ya
Absolutely! Thank you very much for taking the time to do that
My answer would have been carefully!
Sent from my iPhone using Tapatalk
Newbie
The Evotech tail tidy is a breeze to install. The instructions mention the WTF screws, the cables reroute like stack and you can use the OEM indicators.Kawa Ninja 010.jpg
The kit also comes with an adjustable bracket for various size plates.
Site Elder
Swearing at the guy who decided on the two hidden phillips screws??????
jjsC6
I just got my Z1000 on Saturday, and have been doing a TON of reading trying to figure out the best way to get rid of the ugly fender. So as I was reading through this thread, I realized what you were missing...
R&G (1.5-inch) US license plate adapter
If you had that it would probably have been a bit easier, don't know if it would have been $16 easier, but a bit!
2013 ninja 1000 tail section
how do you take off the liscense plate holder on ninja 1000
how to mount rear tail section ta kawasaki nonja motorcycle
how to remove kawasaki sx tail piece
how to remove rear fender on z1000
how to remove stocktail seation on kawasaki sx 1000
how to remove tail of kawasaki z1000?
how to remove z1000
kawasaki ninja 1000 removing tail
ninja 1000 tail remover
ninja 1000 tail tidy
ninja 1000 tidy tail
ninja 1000 tidy tail yes or no
rear fender removal on ninja1000 sx
z1000sx tail removal
