2001 ZX9R STATOR QUESTION important
This is a discussion on 2001 ZX9R STATOR QUESTION important within the 3rd Gen Z1000/Z1000SX/Ninja 1000 forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; well my bike was stolen and droped on its side and lit on fire.. thank god the neighbourhood put out the fire before anything was ...
Results 1 to 4 of 4
    Newbie lafreniere1030's Avatar
    well my bike was stolen and droped on its side and lit on fire.. thank god the neighbourhood put out the fire before anything was burnt.. the side of the stator case is cracked and when the bike is running.. oil comes out of the side.. i was wondering if this was common to have oil in the cover?
    !!! help guys please
    Rising Star haknslash's Avatar
    May 2012
    Central Alabama
    381
    26 times
    Yes some oil can be in there (small amount). These are wet systems afterall.....
    But google searching for you I ran across this from the ZX forum regarding the older ZX9 motors:
    "The stator cover has two "weak points" that could be leaking. The first is the gasket between it and the block, if that's the problem it's as simple as unbolting it, putting in a new gasket and bolting it back down. The other possibility is where the wires pass through, there is a rubber plug that is supposed to prevent oil from leaking out around the wires, check it carefully and if need be add a little high temp RTV."
    2012 Ninja 1000 ABS - Metallic Spark Black/Metallic Flat Micron Gray
    GiPro-DS gear indicator in white ° OEM Ninja gel seat ° TRS/Morimoto 5000k HID ° superbrightleds.com 5500k SMD LED marker lights ° Tankslapper film ° R&G fender eliminator
    Up-And Comer DM~N1K's Avatar
    May 2012
    Lincoln, NE
    30
    48
    next time let it burn and collect the insurance?
2001 zx9r alternator location
goes a zx9 stator cover have oil in it
how to change out a stator in a zx9
how to change stator cover on zx9r
how to test kawasaki zx9r stator
how to test zx9r stator
oil in stator case zx9r
wiring stator kawasaki zx9r
zx9 alternator
zx9 alternator for sale malaysia
zx9 oil in stator
zx9 stator wet
zx9 wet stator
zx9r check stator
?????????? ???????????????? zx9r
