My bike kind of 'coughed' yesterday
This is a discussion on My bike kind of 'coughed' yesterday within the 3rd Gen Z1000/Z1000SX/Ninja 1000 forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; Yesterday when leaving a friends house to head home my bike did something kind of wierd I think. I mean it could of been my ...
Results 1 to 9 of 9
    Rising Star haknslash's Avatar
    May 2012
    Central Alabama
    381
    26 times
    Yesterday when leaving a friends house to head home my bike did something kind of wierd I think. I mean it could of been my imagination but I could of sworn the motor kind of coughed for a split second.
    Here's the scenario:
    Outside temps were in the low 90's.
    Bike was warmed up and at operating temp prior to leaving my house.
    I had been riding on the street about 10 minutes then stopped at a friends house real quick.
    Bike had been sitting at their house turned off for maybe 5-7 minutes.
    Fired bike up and started to head home.
    I was turning right from a dead stop at a busy intersection.
    To quickly get up to the speed and flow of the traffic I rolled into 1st gear moderately (maybe 3/4 throttle) until reaching about 45-50 mph.
    Traffic was coming to a stop and the lanes merge from 2-1 so I had to roll off the throttle and prepare for breaking and merge over.
    As I rolled off throttle I applied just a hair more throttle and heard the bike kind of hiccup or cough for just a split second.
    Pulled in clutch to assess the situation.
    It happened so fast that I didn't have a chance to look at the RPM to see how big of a dip it might of took.
    I revved the bike a little and it seemed and sounded fine. It rode home fine without it doing it again.
    Maybe it was a fluke occurance from getting on the throttle a little then quickly having to get off then back on for a split sec? My VTR1000 used to cough every now and then but that was due to the two massive 48mm flat-side carbs nature. With this being FI bike I wouldn't think this kind of thing would happen. Maybe it was my imagination but I'm pretty sure I hear the motor and bike sort of cough. It didn't make any jolts or noticeable studder that I could tell.
    Wondering if anyone else has experienced this or know what it could be? I go for my 600 mile service soon so I'm going to at minimum let them know it happened so there will be a log of it.
    2012 Ninja 1000 ABS - Metallic Spark Black/Metallic Flat Micron Gray
    GiPro-DS gear indicator in white ° OEM Ninja gel seat ° TRS/Morimoto 5000k HID ° superbrightleds.com 5500k SMD LED marker lights ° Tankslapper film ° R&G fender eliminator
    Rising Star deroz's Avatar
    Aug 2011
    Ohio
    28
    275
    10 times
    Probably normal if it is the fuel cut issue. When you close the throttle at higher than 3500 rpms, the bike will stop the fuel injectors. When you close the throttle, then open it, there will be a very small delay and then what seems to be a burst of power. So if you close, open slightly for a second, then close it again you will get a power kick that will knock you back.
    This is an annoyance that a lot of people dealt with by getting Ivans FCE (fuel cut eliminator) product. This issue usually causes me to grab throttle tighter when I get knocked back, which causes me to roll on more throttle. This is a very stupid "feature", but I have not installed the kit.
    May 2012
    Central Alabama
    381
    26 times
    Yup that sounds like what happened. I will look into buying his FCE if I notice this becomes more apparent. So far its only done it once so maybe it was just the 'right amount' of circumstances to cause it. I'd love to buy the whole Ivan's kit but I'd probably be sleeping in the garage once the wife found out I order more crap
    Nov 2010
    San Jose, CA
    2,020
    80 times
    Mine does the same thing once in a while. I'm assuming it's the fuel cut and I'm keeping an eye on it to make sure it doesn't change/get worse.
    I'm gonna look at possibly eliminating the fuel cut through an ECU flash down the road.
    2011 Ninja 1000 :: Fastest Color :: Akrapovic 4-2-1 :: Pulled Sub Throttle Plates :: PAIR Blocked :: Modded Airbox :: PCV :: Pit Bull Swingarm Spools :: Fuzeblocks Power Distribution :: Gerbing Hookup :: Battery Tender Hookup :: Tank Slapper :: Zero Gravity Double Bubble :: Bags Connection Powered Tank Bag :: Ventura Tail Bag :: Sargent/Squidlius Maximus Seat
    Rising Star sweetlou's Avatar
    Long Island, NY
    411
    12 times
    I get a cough at 2500 RPM. Does anyone know the exact RPM the fuel cuts off at? I'm trying to tune the cough out! I figure if I can add fuel I may be able to avoid it.
    Lou
    [2011 Ninja 1000 Black] [12v Plug] [5000K HIDs] [GPS Mount] [PCV] [Auto Tune] [Full Muzzy Oval] [Modded Air Box] [Subthrottle Plates Removed] [Kleen Air Mod] [CNC Levers] [Givi Rack] [Fenda Extenda] [Muzzy Fender Eliminator] [Puig Screen] [Throttle Boss] [Symtec Heated Grips]
    [2004 KTM 450 EXC and Sumo - Street Legal]
    [1998 ZX6R Track Ready]
    Aug 2011
    Ohio
    28
    275
    10 times
    Ivan's page talks about what the what the fuel cut is, and what the FCE eliminates. It lists 3500rpm and over for the Z1000 (no year, but the FCE is only listed for the 2010+ models.)
    Aug 2011
    Ohio
    28
    275
    10 times
    Quote Originally Posted by sweetlou View Post
    Lou
    It is an ECU issue and I don't think fuel maps alone can fix it. This means a PCV won't help (according to Ivan and other people on this forum).
    Ivan's site says that he expects to offer ECU flashing this fall. I think there is someone else offering them now for $350 if you don't want to wait. Just search the forum. My bike is stock, but when Ivan offers it I think I might go for it. Recently I started to really hate that issue.
    Long Island, NY
    411
    12 times
    Ivan's page says the fuel cut off is at 3600 RPM. I do not notice ANY change in exhaust sound until 2500 when I get a distinct "pop." I was under the assumption the fuel cut off at 2500 but apparently not. Weird...
    Lou
    Rising Star P23D4702's Avatar
    Mar 2011
    OZ
    371
    When i got the the euro link ..OZ cbf to call teh guy ... I bought the FCE immediately (which was today ).. then I said oops i just spent 170 AUD...kisses... its for my safety so i get smooth throttle especially on a corner in the wet... she SAID i get he same think in my mazda(cager) it surges... no further comment... Woman accepted it as a need for safety.. REJOICE and EMBRACE half intelligence !!!!
    Quote Originally Posted by haknslash View Post
    Expect the unexpected !
    Green & Black N1K '11 - Michellin PR3s with 55 rear profile, 5K HID & LED runners, IVANS FCE, Evotech - Tail Tidy & Rad Guard, SW-M irror Extendors, PUIG screen dark smoke, Sargent Seat, Black Brawler pipes, next up pazzo levers.
bike cuts out rolling off throttle
ivans fuel cut eliminator
vtr1000 coughing thru airbox
when i roll off the throttle my bike hiccups
