How to install a fender eliminator on your Ninja 1000
This is a discussion on How to install a fender eliminator on your Ninja 1000 within the 3rd Gen Z1000/Z1000SX/Ninja 1000 forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; Today my R&G "Tail Tidy" fender eliminator came in. The instructions they send and on their website are not 100% acurate. It is based off ...
Results 1 to 15 of 26
Like Tree4Likes
Thread: How to install a fender eliminator on your Ninja 1000
    Rising Star haknslash's Avatar
    May 2012
    Central Alabama
    39
    381
    28 times
    Lightbulb How-to: install a fender eliminator on your Ninja 1000
    Today my R&G "Tail Tidy" fender eliminator came in. The instructions they send and on their website are not 100% acurate. It is based off the Z1000 which there are some differences when installing the kit.
    I made a tutorial video while doing the install. Perhaps it might help someone who has never done one. Of all my bikes this one was more involved than others but pretty straight forward.
    Watch in HD.
    Before
    After
    Before
    After
    The LED unit is a nice clean bright white. No hint of blue or purple. Video screenshots.
    NinjaGreg and twistedthrottle like this.
    2012 Ninja 1000 ABS - Metallic Spark Black/Metallic Flat Micron Gray
    GiPro-DS gear indicator in white ° OEM Ninja gel seat ° TRS/Morimoto 5000k HID ° superbrightleds.com 5500k SMD LED marker lights ° Tankslapper film ° R&G fender eliminator
    Up-And Comer Lechec66's Avatar
    Mar 2012
    Houston, TX
    97
    11 times
    Awesome, thanks for posting
    2011 Black N1K - Arrow Dark Slip On, T-Rex frame sliders, GP Shift by SMR Components, Muzzy Tail Tidy, Apex Riser Clip-ons, ASV levers
    2007 ZX6R - Track Only - Armour Bodies, Woodcraft Rearsets, Two Bros full exhaust, elka shock, bazzaz FI/QS/TC, GPR Steering Damper, Braking Rotors, spiegler brake lines, ASV Levers, CL Brake pads
    Get on the Right Track
    www.sportbiketracktime.com
    www.apexmfg.com
    www.racercafe.com
    Rising Star M1Diesel's Avatar
    Apr 2012
    171
    11 times
    Just installed one yesterday. It was not a Muzzy but after watching the video I wish it was. Mine was a pia to install and not as nice as yours.
    2011 Ninja 1000 Black
    2003 Vmax-sold
    2008 CRF 250x
    2009 KTM 450 xc-f
    May 2012
    Central Alabama
    39
    381
    28 times
    Quote Originally Posted by M1Diesel View Post
    Mine is an R&G. It was pretty straight forward of an install even with the instructions not being accurate. The most time consuming aspect of the install, minus fiddling with the camera angles and such, was trying to bolt it back up using the supplied screws or the stock ones. But after holding my tongue 32° to the left and sipping on good beer, I was able to line it up and get her bolted up .
    One thing worth mentioning but left out of the video is that it would be a good idea to add some blue loctite on the threads to deal with vibes.
    Thanks guys
    Supreme Being Black Sheep's Avatar
    Feb 2008
    Raleigh, North Carolina, USA
    2,775
    219 times
    I just installed the Targa FE and what a PITA it was... looks good now that I am done, but I was really fighting it. My main issue was the wiring for the plate light was too bulky and prevented the tail from going back together properly... took me forever to figure out where the problem was and to get the plastics lined up properly. I replaced the signals in the kit with Rizomas... they are shaped similar to the fronts.
    2012 Kawasaki Ninja 1000 | 2013 mid-fairings for an all Metallic Spark Black finish | OEM Solo Seat Cowl | Puig Smoke Windscreen | Targa Fender Eliminator
    Rizoma Rear Turn Signals | Sato GP style swingarm hooks | M4 GP Style slip-ons | Speigler SS Brake lines | Stripped and Polished wheel lips
    _______________________________________
    North Carolina riders check out: NCSportbikes.com
    May 2012
    Central Alabama
    39
    381
    28 times
    Yup the wiring was a pain for me too since there isn't much room under there. I ran my turn signals wires back under the computer module thing that is in there. That's the way they were routed originally. I tried going a different route but couldn't get the undertail plastic pulled up high enough. This bike is by far the most involved I've ever had when installing something as simple as a fender eliminator lol. Looks so much better now though so all the cursing was worth the trouble
    Site Elder Johnmark101's Avatar
    Feb 2012
    Central Kentucky
    554
    60 times
    Nice instructional video and the FE really cleans up the back of the bike.
    Think I may just use a Dremel and a cutting wheel to cut the stock fender off behind the license plate first and see how that works.
    May 2012
    Central Alabama
    39
    381
    28 times
    Quote Originally Posted by Johnmark101 View Post
    Think I may just use a Dremel and cutting and cut the stock fender off behind the license plate first and see how that works.
    Thanks.
    If you do decide to dremel your stock one off you might want to make sure you leave both of the philips head screws intact or your fender/tag may seperate since its held together by 3 fastners. If you removing just below where the bottom of the tag goes you will be fine.
    Site Elder treestone27's Avatar
    Atlanta GA
    609
    8 times
    does the r&g use the existing blinkers?
    2011 Ninja 1000 (black)
    Sargent Seat / Tankslapper / Q2s (55 in rear) tires / RAM ball clutch mount for brake (1 ball) and clutch (2 balls) for GPS, radar and cupholder / 2 powerlets in the "dash" / yuasa battery tender / sw-motech tank ring and day pack tank bag with power to the bag from powerlets in the dash / uclear hbc 200 in-helmet speakers for music, phone / Garmin 60csx GPS on handlebar via RAM Mount / MRA xScreen Windscreen Extension
    May 2012
    Central Alabama
    39
    381
    28 times
    Quote Originally Posted by treestone27 View Post
    My pics and vid shows it using them, so yes
    From the Z1000 R&G instructions:
    IF REUSING ORIGINAL INDICATORS (TURN SIGNALS) FIT TO NEW LICENCE PLATE BRACKET AS ORIGINAL. IF FITTING MINI-INDICATORS R&G PRODUCT CODE RG370, YOU WILL HAVE TO USE THE INDICATOR ADAPTORS SUPPLIED IN KIT.
    Newbie greenmonster's Avatar
    May 2012
    jacksonville, fl
    12
    where did you buy yours from? I'm looking for one for me 2011 z.
    May 2012
    Central Alabama
    39
    381
    28 times
    Quote Originally Posted by greenmonster View Post
    Twisted Throttle R&G "Tail Tidy" fender eliminator kit for Kawasaki Z1000 '10-, Ninja 1000 '11- - RG.LP0095BK : TwistedThrottle.com. Gave them a shoutout at the intro of the vid . Fast shipping! It's a little pricey but R&G makes nice stuff and its low profile compared to some others.
    Up-And Comer fargingbastige's Avatar
    Apr 2012
    Birmingham, AL
    103
    Great video. Here's the finished product on my Muzzy bracket. It was +/- $60 including shipping and uses all stock wiring connections and turn signals. Took about an hour and a half and 3-4 beers to complete installation. Looking back at the stock fender pictures, it confirms that it was time well spent.
    Go ahead, skin that smoke wagon and see what happens.
    [IMG][/IMG]
    May 2012
    Central Alabama
    39
    381
    28 times
    Looks good man. And yes good beer always make the installs better!
    Up-And Comer HouTexNinja1000's Avatar
    Aug 2011
    Houston, TX
    96
    I installed the Evotech and it was a pain as well. Guess it's just the nature of the beast.
2012 kawasaki z1000 fender eliminator
2012 ninja 1000 fender eliminator
evotech fender eliminator for ninja 1000
fender eliminator ninja 1000
how to install fender eliminator z750
kawasaki ninja 1000 rear
ninja 1000 fender eliminator muzzy instal
ninja fender eliminator before and after
z1000sx undertail
