Strange behavior within first 1100 miles...
This is a discussion on Strange behavior within first 1100 miles... within the 3rd Gen Z1000/Z1000SX/Ninja 1000 forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; I had a missing bolt for holding the front red fender when I took delivery. Then when I was installing Ivan's kit I found numerous ...
I had a missing bolt for holding the front red fender when I took delivery. Then when I was installing Ivan's kit I found numerous fasteners loose. I thought about starting a thread on the subject. The loose issues I am talking about were where things were connected to the frame. From the headlight area to things just under the fairing. All in all I tightened numerous things, some of which were only finger tight.
DM~N1K
which bolts did you guys have fall out? ive hit about the 600 mile mark, just kinda curious
2011 Nija 1000
Full Ivan's kit
UCU reflash for FCE and timing restrictions
05-31-12 09:08 PM
DJB, Lodi
That kinda scares me...
2011 N1K (Ebony): Pro-Bolt Rear Spools - Orbital CF tank pad - Puig Racing Screen/Dark Smoke - 434racer shorty clutch lever
2000 CBR600F4
99 SV650N
Fuel Economy Tracker:
I'm a mn rider too. Where u located? Oh and dealer and done.
Fotoboy
Northern Suburbs but I seriously ride everywhere within 100 miles of Minneapolis on a regular basis. Gotta get out there when you can in this damn state.
2000 CBR600F4
99 SV650N
jadedgamerx
Hear that, bought a new sled last year and well...... Anyway Burnsville here but we ride all over too and been diggin wi roads lately.
The ride into work today was completely uneventful in a good way and the bike definitely has gained some power on the butt dyno... lesson learned: Castrol GTX breaks down FAST. I wouldn't push a batch past 700 miles ever again. We'll see how long the Rotella holds up to my riding style and MN temps. Thanks for the advice everyone.
Also - this thread helped quiet my fears about the Tractorsaki noise a lot:
Freaking out !! N1K Engine Ticking ?
The sound clips posted by motoCYCHO are dead ringerers for how my bike sounds at idle, I'm even a little quieter than his clips now with the fresh oil. Huge props for him taking the time to test out the two different CCTs and record the clips/post for us here. Great forum!
2000 CBR600F4
99 SV650N
Squidlius
Gen 2 FZ1s go 26,000 between valve inspections. 15,000 is not very long for a Japanese bike.
What I don't get is why is it that USA (including California) and Canada Ninja 1000 bikes have the valve check at scheduled at 15k miles, meanwhile the rest of the WORLD has it scheduled for 26k miles.
Before you can be old and wise, you must first be young and stupid - Anonymous
I have the same problem with mine and cant figure it out. Had slip ons when i took it to the dealership to see what was wrong, two weeks later after hearing nothing i call and call. he says that its the exhaust, no backpressure is bad. i said it has a cat underneathe it and i hear of alot of guys running slip ons with stock fuel, he said thats what the prob was cause he put on stock cans and rode it along with 3 other dealership guys and thats definitely it. i angrily go get my bike back to discover 1 mile had been put on it since i left it. i will figure out the problem myself, thats just nonsense!!!!!!!! it had stock cans on when the problem started! dealer ship where i live is terrible. ive ran a few cans of seafoam through mine, to find that the problem is so sparatic i cant tell if it helped or not. hope your dealership figures yours out so i can fix mine. its more than frustrating i know first hand. mine started at 900 miles btw. im disappointed as well, takes away from the new bike feel thats for sure
2011 Black Z1000-Modded stock exhaust, Muzzys tail tidy
07 Honda CRF 450R
Squidlius
I lost two of my windscreen bolts on the ride home from the dealership so obviously somebody forgot to tighten them. I gave the bike the once over as usual when I got home and didn't find anything else loose.
Today I went for a quick ride down to the store to get some smokes. I finally decided to get on it a bit and maybe got around 9k RPM when I heard this horrid "BZZZZZ" sound coming from the front of the bike. I had my visor down so thought for a second maybe it was a fluke thing. Left the store to head back home and got on it again, multiple times getting up around the 8.5-9k RPM range and the same sound was there every time. I flipped my visor up and it seemed to come from the windscreen. I tried to see if grabbing it would muffle the sound any but couldn't ride at those speeds one handed on these roads. Got back to the house and checked the windscreen screws and ALL of them were at a minimum 1 1/4" turns out from snug tight! They turned so easy that at first I had to double check and make sure there wasn't some kind of nut spinning on the back. I didn't get a chance to take the bike back out to see if that was causing the vibrating bzzz sound or what. 1st time I've had the RPM's that high so not sure if it would of always made that sound or just now starting to from fastners being loose. We'll see. I'm going to do a good check on all fastners on my off day.
2012 Ninja 1000 ABS - Metallic Spark Black/Metallic Flat Micron Gray
GiPro-DS gear indicator in white ° OEM Ninja gel seat ° TRS/Morimoto 5000k HID ° superbrightleds.com 5500k SMD LED marker lights ° Tankslapper film ° R&G fender eliminator
haknslash
Wow. It's tough to find good help!
2011 Ninja 1000 :: Fastest Color :: Akrapovic 4-2-1 :: Pulled Sub Throttle Plates :: PAIR Blocked :: Modded Airbox :: PCV :: Pit Bull Swingarm Spools :: Fuzeblocks Power Distribution :: Gerbing Hookup :: Battery Tender Hookup :: Tank Slapper :: Zero Gravity Double Bubble :: Bags Connection Powered Tank Bag :: Ventura Tail Bag :: Sargent/Squidlius Maximus Seat
haknslash
When I put my new Puig on yesterday I made sure the get them REAL tight without stripping them, the buzzing vibrations from the motor seem to really loosen things up on this bike. I think the counter-balance shaft on this motor could have used a little more R&D time for the rev range the bike runs at on the HWY.
2000 CBR600F4
99 SV650N
any more on sputtering? im sick of mine. i took a gopro vid of it tonight acting up. pisses me off. im taking it to a DIFFERENT dealership next time. AJAX KAWASAKI OF OKC HAS THE WORST SERVICE EVER. Gonna put 1 single mile on my bike and say 3 people rode it and figured out it was the exhaust.... SHOULD BE ASHAMED
07 Honda CRF 450R
stevo_88
Small world. I bought my bike at AJAX.
Newbie
jadedgamerx
... lesson learned: Castrol GTX breaks down FAST. I wouldn't push a batch past 700 miles ever again ...
Like car oil? Or did you use motorcycle specific?
foxhound81
Car grade 10W-40 - it was just a break-in oil, but I pushed it too far. Rotella has been working great so far with 1K on the clock.
2000 CBR600F4
99 SV650N
2000 mile service 2010 kawasako z1000
2012 ninja 1000 valve adjustment
2012 ninja 1000 valve adjustment interval
2012 z1000 valve adjustment
2012 z1000 valve adjustment interval
first service on a kawasaki z1000
first service valve adjustment on 2012 z1000
got a brand new kawasaki ninja 2012 the bike when it gets to 8000 rpms it makes a weird sound what is that??
how often should u service a kawasaki z1000
kawazaki z1000 valve adjustment
miles behavors
ninja 1000 adjusting valves
ninja 1000 rotella
storing ninja1000
valve adjustment how to ninja 1000
