Double Powerlet in Dash and Double Ram Mount on Brake/Clutch
This is a discussion on Double Powerlet in Dash and Double Ram Mount on Brake/Clutch within the 3rd Gen Z1000/Z1000SX/Ninja 1000 forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; In case anyone is interested in this sort of mounting scheme. I have 2 powerlets in the dash, and a ram mount on the clutch ...
In case anyone is interested in this sort of mounting scheme. I have 2 powerlets in the dash, and a ram mount on the clutch (2 balls) and on the brake (1 ball). So, I can run power to a radar detector on the right, and run power to both the GPS on left and to a tank bag (and split power inside the tank bag, to iphone and ?). I think the set-up will work well, but I'll need to run the power cords from the powerlets on dash back up to the windscreen then straight through the bars or a full lock turn will cause a problem. More later..........
2011 Ninja 1000 (black)
Sargent Seat / Tankslapper / Q2s (55 in rear) tires / RAM ball clutch mount for brake (1 ball) and clutch (2 balls) for GPS, radar and cupholder / 2 powerlets in the "dash" / yuasa battery tender / sw-motech tank ring and day pack tank bag with power to the bag from powerlets in the dash / uclear hbc 200 in-helmet speakers for music, phone / Garmin 60csx GPS on handlebar via RAM Mount / MRA xScreen Windscreen Extension
powerlet has top quality gear. i ordered the drill bit kit that comes with it. Just drill the two holes, sand them or file them a touch and screw in the powerlets. The only trick to the project for me was running the wires on the left side of the bike. I had to unscrew the tank screw (under the seat), pull the tank up an inch or so, then pull the powerlet cord through with string. The dust boot made tugging the cord through take a few minutes, but once you get the powerlet cord under the tank, it's easy. Now, I can plug the battery tender into the powerlet direclty and connect a voltmeter (in addition to operating the gps, radar and running power to tank bag for iphone). let me know if you have questions.
ps....i didn't need the low profile kit. but, i think i would have drilled it a touch lower because there is a bar behind that location and a touch lower for the drill point would have been better. i drilled in the middle of the flat spot triangle - just go a touch lower. it's easy to pull the panel off.
Looks Great!! almost like it was supposed to be there.
2010 Z1000 Black & Silver (the faster one)
**Custom Fender Eliminator**OES Frame Sliders**Puig Racing Dark Smoke Windscreen**DDM 5000k HID Setup**Dual Carbon Fiber Slip-ons**Symtec Heated Grips**ProGrip 699 Gel Grips**SpeedMetal Jelly Tank Pad - Clear**K&S GT Style Composite Mirrors**Pro Taper Contour Bars(Carmichael Bend)**Bikemaster Aluminum race spools (these do not interfere with stock exhaust)**to be cont'd...
my powerlet just one under my seat to connect thewire from my vest (heated vest rapid fire+heated gloves gerbing with dual temperature wireless controller)
and if i need to connect my optimate 4 on it too IMG_1936.JPGIMG_1935.JPGIMG_1941.JPG
I have the same RAM mount. I ordered it with both the clutch/brake reservoir mount and the bar mount, in hopes that there was enough space on the bar for it to squeeze in. Just an 1/8" too wide so I grinded (ground?) the mount just a tad and it fits.
i keep the windscreen in the middle position - but the wind flows right over the gps. i'll be ordering the longer ram mount arms to get the radar/laser detector middle of the windscreen.
I assume that ya'll have to keep the windshield in the "up" position in order to mount anything on the handlebars - correct?
Other than looking funny sticking up above the screen, why does it matter? I had a GPS mount on my Z1K and there was no windscreen to hide it behind... which reminds me... I left the power cord attached to the bike when I traded it in... DOH!
Because whatever you have mounted on the RAM mounts will smack into the windscreen in the low position when you turn the bars.
Ahh... did not think of that. I still have the naked bike mentality going - no windscreen and everything turns when you move the bars. I guess that will change after I get a little more seat time on the Ninja. I still have to buy a new power cord for my GPS and figure out what mount I want to get...
2012 Kawasaki Ninja 1000 | Black / Micron (for now) | OEM Solo Seat Cowl | Puig Smoke Windscreen | Targa Fender Eliminator | Rizoma Rear Turn Signals | Sato GP style swingarm hooks | M4 GP Style slip-ons
_______________________________________
North Carolina riders check out: NCSportbikes.com
Treestone, do you have a picture of your clutch mount with nothing on it? Wondering how you got the ball on the bottom.
My problem is I have very little room between my tankbag and the windscreen in the low position.
I'll look for a close up of the clutch side. The lower ball comes attached to the RAM mount from the manuf. - it's a dual ball mount. Other than that, it works the same as the single ball mount (just less sliding room to move the mount up and down b/c the lower ball is taking up some room). I don't have problems with the windscreen in any position, but I haven't mounted a tank bag yet (just tail bag). The mount comes close to the tank, but anything mounted is higher than the tank. There's a great SW-Motech system that will allow me to run power from the dash into the tank ring mounted small/medium bag - then I can plug in various devices in the bag (and remove the bag to other bikes with power). My goal is to run the detector and music into the helmet, and have the the ability to take calls from the Mrs.). Here's the tank bag system I'm working on building - 6 part series -
