2011 Z1000 hydraulic clutch, test riding now
This is a discussion on 2011 Z1000 hydraulic clutch, test riding now within the 3rd Gen Z1000/Z1000SX/Ninja 1000 forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; I have put a Hydraulic clutch system on my 2011 Z1000 It's has been ridden for 200kms, and going to have a 600km ride this ...
Results 1 to 15 of 18
    Up-And Comer ALANKAO's Avatar
    Jan 2009
    It's has been ridden for 200kms, and going to have a 600km ride this weekend.
    2011 KAWASAKI Z1000
    ●Zero Gravity DB screen
    ●RG Racing frame slider
    ●RG Racing Engine Cover
    ●RG Racing handlebar weight
    ●Brocks Performance Alien Head Full Black 14" Muffler & Map
    ●Alan Performance Ohlins steering damper bracket
    ●Ivan's FCE & air box mod
    ●4Racing rearset
    ●Two Brothers Juicebox Pro
    ●Z1000 Hydrualic clutch system
    2004 HONDA CB400SF
    2005 YAMAHA FJR1300
    2006 KAWASAKI MEANSTREAK 1600
    Up-And Comer kevxtx's Avatar
    Aug 2011
    Brisbane Australia
    46
    How does it feel compared to the standard set up?
    Rising Star DJB, Lodi's Avatar
    Near Chicago
    369
    17 times
    Can you post the links for checking out this mod?
    2011 Nija 1000
    Full Ivan's kit
    UCU reflash for FCE and timing restrictions
    Jan 2009
    Hello Kevxtx,
    Smooth.....smooth....smooth
    no more sore wrist
    2011 KAWASAKI Z1000
    ●4Racing rearset
    2004 HONDA CB400SF
    2005 YAMAHA FJR1300
    Jan 2009
    Quote Originally Posted by DJB, Lodi View Post
    it's how it works~
    http://youtu.be/wIOT8M42EY0
    2011 KAWASAKI Z1000
    ●4Racing rearset
    2004 HONDA CB400SF
    2005 YAMAHA FJR1300
    Site Elder rowdyred94's Avatar
    Feb 2012
    St. Cloud, Minnesota
    579
    45 times
    I was disappointed that the Ninja didn't have this after having it on my "cheapo" Bandit. I haven't had any soreness, but the smoothness of a fluid system is nice. Please post more details.
    Oh-12 Ninja 1000 ABS in Spark Black/Micron Gray... 9,000 happy miles and counting | Blog
    T-Rex Racing sliders ~ 16-tooth front sprocket ~ Puig screen ~ The2Wheels levers ~ PR2 out back ~ Symtec grip heaters ~ Givi toprack and V46 case ~ Garmin Zuma 550 + Cardo Scala Rider Q2
    '02 Bandit 12S (sold after 10 years and 47,000 miles)
    'Busa shock ~ Racetech forks ~ Holeshot stage 1 & pipe ~ Hella headlights ~ CBRXX clipons
    '02 Honda XR50R, '92 Honda CR125R
    Site Elder JSharp's Avatar
    Jan 2011
    East Central IL
    56
    738
    25 times
    This is a mod I'd be interested in if the price isn't too high.
    '11 Ninja 1000
    Fuelly
    Near Chicago
    369
    17 times
    Alankao, could you please post a site to purchase the hydraulic clutch?
    Thanks, Dennis
    2011 Nija 1000
    Full Ivan's kit
    Up-And Comer mikelebron's Avatar
    Apr 2012
    Long Island NY
    79
    I dont see the benefit... Typical hydraulic clutch actually actuates the pressure plates through a caliper - similar to a brake caliper.... All this is actuating is the original mechanism that actuates the pressure plate mechanically... In other words I cant see you getting any better fidelity or accuracy in your throw as you are dependent on the original fundamental design... Of course I am speculating all of this based on the pics.. I would love to see the install procedures!
    Site Elder motoCYCHO's Avatar
    Sep 2010
    SLC, UT
    43
    681
    23 times
    Quote Originally Posted by mikelebron View Post
    Hydraulic clutches don't use a caliper.. but they do move a piston at a slave cylinder. It is usually directly behind a push rod which mechanically pushes the pressure plate rather than a pivot arm down from the clutch cover.. but the result is basically the same.
    The main advantage to a hydraulic clutch system is to make the pull on the lever easier. You loose the feel you get through the cable for sure. It's not a problem if you commute.. but if you do any spirited riding that involves modulated use of the clutch, it will rob you of the feel you need to get the best feel for the friction point etc. The best hydraulic clutches out there are the radial type, like used on the ZX-14, which translate feel much better to the lever... albeit, still not as good as a cable.
    Personally.. I like this bike with a cable. Feeling the take-up is important for sport riding. Still a cool mod though.
    - Rev. CYCHO -
    - Church of the Holy Smoke -
    Apr 2012
    Long Island NY
    79
    If that be the case, (I have been riding a VROD now for 5 years which is hydraulic and am considering a N1K - so I am lurking) seems this mode gives you the best of both worlds from the picture.... My last bike without hydraulic clutch was a CBR600...
    I have to say though the hydraulic clutch on my VROD is damn near perfect... but its like comparing apples and oranges..
    Anyway... agree.. Real nice mod!....
    Rising Star RBizzle's Avatar
    Feb 2012
    Aloha, OR
    325
    geez i keep coming back to this. are we ever getting a link to this product? haha
    2010 Z1000 Black & Silver (the faster one)
    **Custom Fender Eliminator**OES Frame Sliders**Puig Racing Dark Smoke Windscreen**DDM 5000k HID Setup**Dual Carbon Fiber Slip-ons**Symtec Heated Grips**ProGrip 699 Gel Grips**SpeedMetal Jelly Tank Pad - Clear**K&S GT Style Composite Mirrors**Pro Taper Contour Bars(Carmichael Bend)**Bikemaster Aluminum race spools (these do not interfere with stock exhaust)**to be cont'd...
    Sep 2010
    SLC, UT
    43
    681
    23 times
    Quote Originally Posted by RBizzle View Post
    Might be a Magura product? I know they make one for Buell... this might be an adaptation of that product?
    - Rev. CYCHO -
    Rising Star haknslash's Avatar
    May 2012
    Central Alabama
    381
    26 times
    I've had hydraulic clutches on a few of my bikes and didn't really notice any significant lack of feel. It is different but I think it's something you end up getting used to then it becomes normal feeling and you learn to feed in the power differently. It's not a big change or at least wasn't for me. It may be different on the Z1000/N1K? I ride dirt bikes as well that have with hydraulic clutches so clutch modulation and feel are critical and never had any issues there although the clutches are much lighter feeling than say a street bike.
    The advantages:
    -less maintenance
    -no risk of cable breaking
    -reduced effort and fatigue
    The disadvantegs:
    -pricey
    -can offer less feel than cable to some but something you can get used to
    -more weight
    Personally I wouldn't mind a hydraulic clutch for the N1K. I did a google search and so far only ran across some guy on a beneli forum saying he tried a ebay kit on his brothers Z1000 that apperently would not fit on the Beneli as advertised. There is a link to the ebay store site within this link hydraulic clutch conversion kit - Benelliforum- Benelli Discussions. Doesn't look like the same master cylinder as the one ALANKAO used on his Z1000. The slave cylinder looks similar but not exactly the same either.
    I did a hydraulic clutch conversion ony my Victory Jackpot and loved it. You can check my youtube channel to see my installation how-to. The same process would apply to say a Z1000 or other bike if you're just curious what all is involved. It's a fairly straight forward process so long as there is a kit that will work for the bike. Victory's have a known problem with snapping cable clutches and it happened to me as I was coming to a stop at a busy intersection. Thankfully I was able to get off the side of the road before possibly having a wreck with the care in front of me. It was a good 'piece of mind' mod if for nothing else, although it was a pricey mod. So that's the main reason why I converted.
    Up-And Comer arshishb's Avatar
    Aug 2011
    118
    Prior to the N1K I had an 06 CBR 1K which had a hydraulic clutch. I hated it. Lack of feel as previously mentioned, major PITA to bleed it & really effort required I felt was actually more. Prior to the CBR I had an 06 GSXR 1K that had a cable clutch which was buttery smooth & usually required only 2 fingers to actuate.
    I am glad the N1K has a cable clutch, easy to adjust, easy to replace & no need to worry about the oil going bad. Ever notice the brake fluid in hydraulic clutches are always black?
advantage hydraulic clutch system motorcycle
convert clutch to hydraulic kawasaki ninja 1000
hydraulic clutch by st cloud
hydraulic clutch kit for victory
hydraulic clutch kit ninja
hydraulic vs cable clutch motorcycle
magura clutch for ninja 1000
motorcycle hydraulic clutch conversion kit
ninja 1000 hydraulic clutch
victory hydraulic clutch conversion
victory hydraulic clutch kit
what are the advantages of a hydraulic clutch for motorcycle
z1000 hydraulic clutch
z1000 hydraulic clutch conversion
z1000 r&g clutch cover fitting
