My NINJA 1000... When the second to the last bar goes out, and I have only the bottom bar showing but NOT flashing I have 1 gallon left. When the bottom bar starts flashing I have .7 gallons left. I have confirmed this multiple times.
This is a discussion on so... within the 3rd Gen Z1000/Z1000SX/Ninja 1000 forums, part of the Kawasaki Z1000, Ninja 1000, Z750 & Z-750S category; My NINJA 1000... When the second to the last bar goes out, and I have only the bottom bar showing but NOT flashing I have ...
2011 Ninja 1000 - 2012 Ducati Panigale ABS - 2013 BMW 1600GT
2010 Z1000 Black & Silver (the faster one)
**Custom Fender Eliminator**OES Frame Sliders**Puig Racing Dark Smoke Windscreen**DDM 5000k HID Setup**Dual Carbon Fiber Slip-ons**Symtec Heated Grips**ProGrip 699 Gel Grips**SpeedMetal Jelly Tank Pad - Clear**K&S GT Style Composite Mirrors**Pro Taper Contour Bars(Carmichael Bend)**Bikemaster Aluminum race spools (these do not interfere with stock exhaust)**to be cont'd...
CUSTOM METALLIC BURNT CANDY ORANGE and BLACK 2010 Z1000 :0)
FMF APEX slipon exhaust, CRG Arrows W/ RS CUSTOM barends, Blue CoreMoto SS brake lines, Pazzo Smoke Shorty Levers, Custom LED Intergrated Taillight, XenTec 35W HID's ( 5000K Bulbs ), OES Frame Sliders, Baldwin pillion seat, Keiti Tank Pad, Tech Spec C3 Tank Grips, swing arm spools
I've seen Ninjas pull better numbers than Zs even with a (SLIGHTLY) smaller airbox.
2011 Ninja 1000 :: Fastest Color :: Akrapovic 4-2-1 :: Pulled Sub Throttle Plates :: PAIR Blocked :: Modded Airbox :: PCV :: Pit Bull Swingarm Spools :: Fuzeblocks Power Distribution :: Gerbing Hookup :: Battery Tender Hookup :: Tank Slapper :: Zero Gravity Double Bubble :: Bags Connection Powered Tank Bag :: Ventura Tail Bag :: Sargent/Squidlius Maximus Seat
That makes sense. I assumed there was a gallon left when the flashing started and ended up running out 1/4 mile from a station. On the opposite side of an interstate bridge of course so pushing was out of the question.
From dry I put over 5 gallons in, almost 5.1 gallons but I was up into the filler neck.
'11 Ninja 1000
Fuelly
2011 Ninja 1000 - black (cuz it's faster)
Kawasaki rear seat cowl
Lawst Caws frame plugs
Muzzy's Fender Eliminator
Sato Racing frame sliders
HealTeck GIPro-DS gear indicator
Sargent seat
A1A SPORTBIKE Spiked Windscreen & Fairing bolts
Powerbronze dark tint windscreen
Expect the unexpected !
Green & Black N1K '11 - Michellin PR3s with 55 rear profile, 5K HID & LED runners, IVANS FCE, Evotech - Tail Tidy & Rad Guard, SW-M irror Extendors, PUIG screen dark smoke, Sargent Seat, Black Brawler pipes, next up pazzo levers.
if you wheelie it all the way home you can make it!![]()
AKRA FULL RACE Ti DYNOJET PCV IVAN'S PERF. FCE - AIRBOX MOD BMC FLTR, CUST. MAP,16/42 GEARING, BLKOFF PLATES
PAZZ0 SHORTIES ESCORT 9500IX WITH LEGAL SPEEDING'S H.A.R.D SYSTEM RIZOMA HDLEBRZ & CLAMP, GRIPS, BAR ENDS, F & R BRAKE RESV, EXHAUST HANGER, CHNGRD, 812 MIRRORS
POWERBRONZE WINDSCREEN, CF BELLYPAN, HGER EVOTECH RAD GUARD & TAIL TIDY
"I readjusted my suspension and bought the dvd Twist of the Wrist 2 and readjusted my style of riding. All good now."
- Fotoboy
Fuel indicator and fuel gauge are independent systems. Maybe your floater is stuck anywhere inside the tank. The fuel (reserve) indicator simply recognises dry or wet, which means the fuel level is below when it is dry.
So trust always your fuel indicator, no mechanics inside. ;-)
My last bike simply had a light that came on when I was low on fuel. That was pretty simple and effective!
I agree, I would rather have a temperature gauge and a gear indicator than our silly fuel tank level thing. I dont care if I have a half tank... I only care when I am empty!
Lou
[2011 Ninja 1000 Black] [12v Plug] [5000K HIDs] [GPS Mount] [PCV] [Auto Tune] [Full Muzzy Oval] [Modded Air Box] [Subthrottle Plates Removed] [Kleen Air Mod] [CNC Levers] [Givi Rack] [Fenda Extenda] [Muzzy Fender Eliminator] [Puig Screen] [Throttle Boss] [Symtec Heated Grips]
[2004 KTM 450 EXC and Sumo - Street Legal]
[1998 ZX6R Track Ready]
