I remember seeing somewhere on Ebay that you could change your headlights so that both sides came on "dipped" and also when going to high beam both were full on, has anyone done this? is it easy to do? is there any problems with the possibility of the bike going BOOM! and where the F8ck can i get one?, searched ebay and either i'm a right muppet and can't see it now or its no longer sold any takers?
Use the search engine here to see if you find info on it. Type in "headlight" or something similar and you should find it. Good luck. Someone spoke of this not too long ago.:alcy:
thanks for this, looked up the Dutch site and close but..... still seems that one side side would be brighter than the other, and being a right pain i like symmetry!!!! so will keep looking.
One side will be brighter because of the way that the beam is deflected on the reflector at the back this is to give it a wider pattern and more 'Depth' and to fill in the area missing from the dip beam.
The one burns at like 20 or 40% while on dims. So yeah, you may notice a difference but I think that's as good as it gets. Unless there is a way to mod it yourself by putting another dim bulb set-up on the bright side.:dunno:
